Gionnirocket
- USA
- City
- Y. O.
A decent aquarium heater is a cheap reliable submersible heater.
And how would you use that?
Put it in the toilet tank and plug it in.And how would you use that?
bidets don't get water from the tank.Put it in the toilet tank and plug it in.
Oh, thanks for the info. That makes sensebidets don't get water from the tank.
Seems easy and cheap to make your own bidet, with temp and pressure dialed in, if you have an electrical outlet to plug into. Aquarium heater in the tank, and aquarium pump to power the hosedown.bidets don't get water from the tank.
You might take a look at heat pump water heaters as well. I confess to not knowing anything about them but I did have a heat pump installed to heat my house a couple of years ago and they cost nearly the same to use as buying firewood and a lot less than most other mechanical heat sources.I am also looking into converting from a water heater tank to tankless water heater. The latter does have advantages that are attractive.
Let us know how that works out for you.... smh...Seems easy and cheap to make your own bidet, with temp and pressure dialed in, if you have an electrical outlet to plug into. Aquarium heater in the tank, and aquarium pump to power the hosedown.
why reinvent the wheel? an aquarium pump would not supply enough pressure its not exactly expensive to buy a setup.Seems easy and cheap to make your own bidet, with temp and pressure dialed in, if you have an electrical outlet to plug into. Aquarium heater in the tank, and aquarium pump to power the hosedown.
There's enough pressure from ordinary aquarium pumps to do anything you'd need to do, but to me it seems like it would be better to have more flow than to have higher pressure. Never tried one so it's just my usual DIYer approach. I see some of them are the same price as a new ebike battery.why reinvent the wheel? an aquarium pump would not supply enough pressure its not exactly expensive to buy a setup.
nope it would not you need pressure. believe me you need it. for 200.00 it would be pointless to try to make it. if you can handle cold water its even cheaper.There's enough pressure from ordinary aquarium pumps to do anything you'd need to do, but to me it seems like it would be better to have more flow than to have higher pressure. Never tried one so it's just my usual DIYer approach. I see some of them are the same price as a new ebike battery.
More pressure than a waterpick? heh hehnope it would not you need pressure. believe me you need it.
30 to 40 psi I would say household pressure.More pressure than a waterpick? heh heh
Rules out the squirt gun theory.30 to 40 psi I would say household pressure.
yep.Rules out the squirt gun theory.
Most revers osmosis membranes are designed to work with 60 PSI or higher water pressure, where they are tested to yield a stable rejection rate of at least 97.5%. If the water pressure feeding an RO system is less than that, the system will produce less water and at a lower quality.
That portable style is a good idea for camping. Some of the squeeze bottles they use are very flexible so provide a good flow easily.Been using one for years and will not go back to TP usage. Refreshing and a good thorough cleaning. The "peanut butter out of shag carpeting with a paper towel", analogy is the very reason why I switched over to that type of cleansing. You could also opt for a portable style using a squeeze bottle with a curved tube.
I used one of those fo a bit but its a lot more hassle.That portable style is a good idea for camping. Some of the squeeze bottles they use are very flexible so provide a good flow easily.
