scott jewell
I have done some low budget chain drives with several Unite motors using 20" wheels on a 24" bike and have two motors front and rear on a 20" BMX.
I also have two hub motors on bikes but am looking at a belt drive instead of a jack-shaft for a 29" wheel on my new project. A 24 volt 500 watt 2,500 rpm motor on a rear rack .
I priced the sheave kit but am looking specifically for the motor attachment part. It is a dual D bore shaft.
With disk brakes front and rear the rear rack will be a challenge but sure they make one. I am looking that up now.
I have a simple bag which straps to the handlebars from another build. It held a controller and is big enough for two LiPo packs. I want a simple low budget build. At 36 volts rpm is 3750 I believe so am seeking 14 to 1 reduction for approx. 23 mph gearing.
The sheath comes in one size so the motor pulley needs to be the right size. If there is no such part then a steel pulley could be used and a 11 tooth #415 sprocket could be used and holes drilled into the pulley wheel and attached together by bolts.
My first build was a Unite 1,000 watt replacement for a stock 24V 450 watt Currie ezip. I bolted it to the rear rack which held the SLA box and did a battery mount on the frame towards the front for weight distribution so I could haul a lot of cargo. Thanks and please let me know of any parts or kits I can use.
