BBSO2 THROTTLE FIX
post911
OKEY GUYS MY MOSSO BY LUNA CYCLES EQUIPPED WITH bbso2 52v started showing slow punch off the line few days ago,
first i thought it could be the battery since i it came with the bike and i m not really good at taking care of batteries like we all should, so i plugged my mighty mini with my drift trike and the trike is performing 100% because stock trike battery is 36v so i can tell when 52v is plugged in,
to cut the story short, i unplugged the throttle cable while swapping the american brake lever setup to british,meaning front brake to the right and vice versa, and then plugged back in the throttle plug and the same exciting punch came back to life...
really happy,
i wonder if static charge made the throttle mode act up on me???
More likely the connector got a little corrosion in it. The throttle has a magnetic sensor chip, and all chips are vulnerable to static, but being a magnet type, it's more resistant.
I have throttles with loose connectors laying around and nothing ever happens to them.
i do night riding and here on long island the air has ton of moist,i wonder if that was the case.
Make ACF50 a part of you tool box. It was developed for avionics. Perfect for eBikes electrical connections.
“If you live in an area near bodies of fresh or salt water, or that regularly experience high humidity, snow or rain, and you own and ride motorcycles that have parts prone to corrosion, well, I suggest you move. Kidding, of course. No matter where you keep your bike it can fall victim to corrosion, particularly if you have to park it outside. Heck, even in drought-stricken California, those of us who live near the ocean have to regularly wash off the film of salt water mist that will rust chrome, corrode metal and kill electrical connections practically overnight.
Corrosion is an even more serious problem in the aircraft industry, where planes are exposed to extreme weather and temperature variations. Lear Chemical Research developed ACF-50 to protect aircraft and their electrical systems from corrosion, so as you might imagine this anti-corrosion formula works quite well on motorcycles. Whether you spray on the thin clear fluid or wipe it on with a rag, Lear says ACF-50’s polar bonding technology forms a non-greasy “hydrophobic” film on the metal surface, neutralizing existing corrosion and road salt and removing and repelling moisture. It’s safe on chrome, paint and plastic, and electrical components like multi-pin plugs, handlebar controls and switches can benefit from a light treatment. Its chemistry protects engine cases and cooling fins, radiators and forks, and its capillary action gets into places where waxes can’t, penetrating around bolts, screws and other hardware, protecting them from galvanic corrosion. It even works pretty well as a light-duty lubricant for locks and latches and such, and is better for corrosion protection on your bike than something like WD-40, which is solvent based.
Lacking a motorcycle that I was willing to allow parts of to corrode and rust for a test, I dug out a blade for my table saw, wiped the lower half with ACF-50 and leaned it up against the fence around my lawn, exposing it to the night air, sprinklers and moisture from the grass. After 10 weeks the back and top half had a thick patina of rust, but the ACF-50 coated area was still pristine. Now I have started using ACF-50 on the bolt heads, engine cases and engine guards on my most-ridden bike, and I have also used it on battery terminals, our bicycles and the lawnmower with equally good results. One application is good for 6-12 months, and you can apply it anywhere except brake rotors, tires, natural rubber or LCD/LED screens. Powersports vehicles like ATVs and snowmobiles that are regularly ridden in wet or muddy conditions stand to benefit from ACF-50 even more, and Lear offers Corrosion Block spray and grease for more extreme needs (like boats and PWCs).
Lear also has larger pump packaging, but I find for home use that the 13-ounce aerosol can is plenty. The can is 95-percent product, with little propellant, so you have to give it a good shake and make sure the can is warm (let it sit in some warm water, for example) before spraying, or it will come out in a stream instead of a spray. It retails for $14.95.
i will look into it,
but i am currently using wd40,
i just spray it on long handle medium hard bristle brush and brush the engine parts all the rubber housing the door rubber inserts etc, works great and keeps the components rust free and soft as new.
WD 40 is a solvent and great for many uses, but it has very low hygroscopic properties. WD doesn't have the long term protection qualities either. In the last few years, it's crossed over from aviation to the MC market. There are similar products, another is Boeshield. I figure if it's good enough for MilSpec aviation and general aviation, it'll be just fine for my eBikes.
