Is there a chart or a way to figure charge percent based on voltage level for a 48v 15a battery?
darksky Member Region USA Feb 17, 2021 #1 Is there a chart or a way to figure charge percent based on voltage level for a 48v 15a battery?
darksky Member Region USA Feb 18, 2021 #3 Looks like I should use the column for the 52 volt battery since the specs for my 48 volt battery says 58.8 volts at full charge. Thanks for the chart.
T Terry777 Guest Feb 18, 2021 #4 My 48v is 54.4 @ full charge and I’m sure it’s set to cut off @ 41v for empty!
