6zfshdb
- USA
- City
- Northeast Pennsylvania
I've been wrestling with this non linear voltage drop issue ever since I bought my first e-bike. The displays on some e-bikes are better than others at estimating range but most still rely on voltage to compute the results. My bike has only a simple 5 bar gauge which is practically useless to determine range
The only real way to determine SOC is to measure ampere hours consumed. I eventually found this gauge which does just that. It's mainly used in marine or R/V applications.
You set the ampere hour capacity of any battery up to 80V and the gauge measures the AH consumed giving you an accurate percentage of power left. It has a 10 bar visual indicator as well as the actual % remaining. It also reads voltage and real time current drain. I like this feature since you can easily see how your pedal effort affects current consumption.
You can enter any value for AH capacity which means you can make allowance for battery cutoff voltage and loss of capacity due to age. For example, I enter 13.78 AH for my 52V 15AH battery which allows for the cutoff voltage set by the controller. For those who practice the 80 / 20 rule, It can also be set to reach zero when 20% charge remains.
Unfortunately, some DIY is required to mount it on a bike. The face of the gauge is weatherproof but the housing is not. It must be mounted in a weatherproof enclosure. It also requires installing a shunt in bike's the motor circuit.
Anyone interested can view this post on how I mounted the gauge:
electricbikereview.com
New 80V 50A 100A 350A Battery Capacity Tester Coulomb Meter Battery Indicator | eBay
We will send you a new one after receiving the defective item.
www.ebay.com
Accurate Battery Gauge Project
I've searched in vain for some time now for an accurate, programmable, handlebar mounted battery gauge. Some high end bikes come equipped with this type of gauge and the displays on many others are up-gradable. Unfortunately, the controller on my bike isn't one of them. The battery gauges on...
