Do you have a multimeter?Bike is dead battery is ok could the problem be the controller in the motor
Yes i am not very good at using itDo you have a multimeter?
Which Bafang Motor?Yes i am not very good at using it
Thank you I will try it and I will check my display thank you have a great weekendShould be pretty easy to use it, watch a Youtube Video or two.
Assuming your battery works, you will need to test that power going into the controller from the battery. I just had the same problem. My BMS on my battery would not wake up because I wasn't getting power to the two small BMS power leads. I had bad connections at the battery cradle. No power to the controller. I have Bafang Ultra.
Check that the power is going into the controller at the controller/battery connections.
Then check if power is coming out of the controller to the motor at the motor.
Aslo my bike died on me this year, it was a bad display.
Hi William,Bike is dead battery is ok could the problem be the controller in the motor
Sorry I took so long to get back I had my motor tested I was told it was the controller I took it off and it smells burnt I am going to order a controller in the summer as I don't use the bike much in winter but my issue is different from yours I have no power anywhere on my bike it might pay to get your bike tested could be the controller on your bike anyway best of luck fixing it kind regards williamHi William,
I am curious if you have been able to fix it? I have exact the same issue. My son left his bike with a one day old bafang middrive BBS01 out in the rain.....
next morning it would not drive. The battery and the lcd screen and headlight are working, but not the motor.
I opened the controller of the motor, but it was completely dry, and also all the connecters, I took them apart and put them in a bag of rice for five days. So they are dry to.
But now I assume for some reason the motor is not getting any electric current...
I am curious if you were able to fix yours?
Kind regards Fredric
