Bafang BBSxx series, Apple Mac access to programming!!
@tomjasz
I'm still using the Fancy USAF approved ACF-50, but I use it conservatively because I'm still saving up for the Lear jet to use it on.
Maybe I can find a cheaper used Jet? 🤔
Airplanes are cheaper, and I've got the Grease for one, but I don't know what will happen if I spray Jet lube on an Airplane??
I remember that you said the Krown KL73 had a pretty good spec sheet, and I prefer it.
It's a lot more viscous and it has more staying power.
I like to start with KP53 and let it soak in, then top-coat it with KL73 because it doesn't creep as good as the penetrant.
I've got this stuff too,..
It's Pretty Slick s*it !!
BafangWebConfig
Cross-platform browser based configuration tool for Bafang BBSxx e-bike motors, runs on Mac, Linux or Windows. It requires a browser with support for Web Serial API, and should work on any recent version of Chrome, Opera or Edge.
Run online​
Click here to start the tool.
Install & run locally​
Download or clone the repository and open BafangWebCfg.html in your browser.
Notes​
USE AT YOUR OWN RISK! Bad settings can fry your motor controller.
If you find any bugs micrĂłfono no funciona en Mac soluciĂłn, please report them here.
Thanks to Stefan Penov (https://penoff.me/2016/01/13/e-bike-conversion-software/) and Philipp Sandhaus (https://github.com/philippsandhaus/bafang-python) for their prior work on deciphering the original Bafang Config Tool source code and communication protocol.
Work perfectly for me.
