I have been under the impression that hub drives don't work well for heavy loads on steep hills, especially at lower speeds such as scenarios where the terrain limits your speed due to tight or technical riding. My understanding was the motors work best at certain (high) RPMs, and the hub motors in particular can't keep that up as your speed drops because they don't have access to the gearing on the bike.
However, I am now seeing some hub drives are mentioned to be geared, and even with pretty impressive torque ratings (95 nm on the
Ride1Up LMT'D for example). I was told by a LBS selling
Aventon Aventures the hub motors work fine for big hills for the big heavy (73 lbs) bike with a 400 lb payload capacity. I was skeptical but one of the forum users on the Aventon section confirmed riding up 10% grade hill at 12 mph using throttle only without issue, though for only ~0.5 miles.
My intended use would on occasion see me riding off-road hills averaging 11% grade for 2.5-4 miles, with rider + gear at ~275 lbs, occasionally towing a trailer for an additional ~50-75 lbs. I have tried this with one of the
specialized brose 90 nm bikes and it handled it like a champ in the lowest gear without any overheating (excep the brakes on the way down, hah). Is it realistic to think a hub motor could also perform something like this? If so, that opens a much larger budget friendly range of options.
