Sounds like a regular hub motor noise at high speeds. A higher powered motor will make more noises. Its kinda like comparing a v4 to a v8 for example.
A hub motor contains planetary gears inside that power the hub and wheel. When in heavy use, those gears will make noises; this is normal.
