Anyone good at math?
No its all one if you go far enough away.
I was looking up a Turkey Vulture flying in the distance yesterday, and noticed another one flying much further away.
Then the further bird started cornering and accelerating So Fast that it was clearly pulling 40-50 G's
Turned out it was a Starling pestering the Turkey Vulture
To return to our moutons...
Gasoline is about €2 per litre. A euro is $1.15 today, so $2.30 per litre. 3.78 liters to a US gallon. So $2.30 x 3.78 = $8.69 per gallon.
So with these figures, what do I multiply together to have a single figure by which I can figure out the $ per gal cost? (I just want one step, not a bloody math meltdown! )
You simply multiply whatever your cost per liter is by 3.78, and that will give you the cost per US gallon.
The tricky part is converting to mpg when they sell gas buy the liter in Canada, and we measure in km now as well.
My dad wanted a single figure to convert his mileage per tank of gas to MPG that he was familiar with from before we switched to the metric system.
It was back in the early 80's about 3 years after we converted to the metric system, and we used the British gallon before we switched to metric, so,..
I told dad to just do his calculation for mpg using the km and liter numbers he had, then multiply that number by 2.82 to convert it to MPG
(I just spent ½ an hour trying to calculate that number again.
I gave up, and asked the robot,..😁)
No, that will give me the price in euros per gallon. I'm trying to find the one factor that will give me the equivalent cost in dollars per gallon. In other words, do both the currency exchange AND change of units with just one factor.
Both the price at your pumps, and the currency exchange are always changing, so I'm pretty sure you'll need to do the two calculations?
4.5 in an Empire gallon.
Interestingly, there's 4.54 liters in an Imperial gallon, and there's 454 grams in a pound.
We used to have an Oldsmobile Delta 88 with a 454 engine and a four barrel carb.
It had a one gallon engine.
Imperial gallon. 😁
You wrote your own equation and solved it.
(euro/liter × dollar/euro × 3.78) = dollar/gallon
Ive stopped looking at the price, the 30p gap between petrol/gas and diesel is depressing, diesel used to be that much cheaper till we started using it in cars.
Theres a whole chunk of the elite running around in gold yachts off the back of that 60p increase.
That is two steps. Also the slashes are confusing to me. I suppose you mean ÷...
I want one step. I'm not that fusyy about the exchange rate going up or down a few points. I just want one factor to multiply the €2 price per litre by to come up with the price per gallon. Should I multiply $2.15 by 3.78? Or divide 3.78 by 2.15? Then when I want to translate the euro per litre price into the price in dollars for a gallon, would I multiply by the resultant figure??
