jhgoodwin
Hi All,
I am interested in adding lights to my ebike (Ecotric 500W 48V folding fat tire mini bike).
I thought before changing it, I should seek some advice from those with more knowledge.
I am looking for a good way to get a bright headlight, and some decent tail light functions.
I thought about getting parts about like this and some wire.
The gist is that I'd tap into the battery's 48V line with a fuse for the headlights, hooking the handlebar switch to that circuit.
On the same switch, I'd hook up the DC-DC inverter to run the 12V power to power the tail lights.
I checked the one unattached black/red wire coming off the controller and it gives 4.5V when the bike is switched on.
There's another plug which has a rubber cover which I assume is the TTL connection.
The controller stow area is quite packed when I push all the wires back in, but could potentially be improved if I shortened a few wires or used a better wiring harness design.
Advice is welcome.
Advice is welcome.
