smorgasbord
- USA
I've been using NixFrixShun Ultimate Chain Lube on my chain for a few years now and been pretty happy (not that that means anything since there are so many factors affecting chain longetivity).
Lately I've noticed new spray-based products aimed at the bicycle market. What's interesting is that this one from DuPont advertises that it is "Wax-based":
A month ago I ordered NixFrixShun's new Green Genie lube but haven't yet used it.
- Specifically formulated for chains on motorcycles, ATVs, bicycles and dirt bikes
- O-ring safe formula prevents the buildup of dirt and grime using a patented self-cleaning wax and resists fling-off
- Contains molybdenum and Teflon fluoropolymer for enhanced wear protection
- Contains corrosion inhibitors to fight rust and protect during wet or salt-air rides
- Dirt-resistant dry lubricant
- Contains Teflon and Moly for wear protection
- Water resistant and Non-staining
- Apply this lubricant to your bike chain for high-performing lubrication for dry, wet, or varying conditions. The fast and easy-to-use formula helps prevent squeaks and extends the life of your chain
- This formula contains corrosion inhibitors for long-term optimal chain performance
- Prevents friction damage and helps extend chain life for your bike. The no-wax formula will not build up inside chain links and drivetrain. Ride with chains you can trust in both dry and wet conditions
- Our entire product line has undergone extensive testing at the hands of internal and 3rd party scientists, bicycle retailers, and professional mechanics. Experience the difference of a professional-grade formula
