Since my right hand control is the rear disk, my mnemonic is "Right and Lurch" ... rarely use the left control for the front disk.You could have some sort of mechanical issue, although I agree with the others that it is most likely a matter of getting used to how much hand pressure you need to apply to the brake levers. Is this a new bike? Have you been riding long? What kind of brakes are they?
There are a lot of opinions on this, but for normal stopping/ slowing down, I use the rear brake first and hardest, adding front brake as needed, often intermittently. Regardless, only apply as much pressure as you need, no more. (If you're going over the handlebars, you're applying too much pressure!)
TT
This is the logic I was use to on motorcycles all my life, and it also make sense as you don't want to be twisting that throttle and braking at the same time.
Well then I'll offer him this advice... a few drops of oil on the rotors will smooth your brakingFor whatever it's worth, ASATKat seems to be one of those people who posts very seldom and never follows up with another question or other reply.
TT
@Gionnirocket never kids about bikes...Yes,..
We were kidding.
Here's a video showing how to replace brake pads contaminated with WD-40,..
