Stefan Mikes
Gravel e-biker
- Europe
- City
- Mazovia, PL
I'm not sure how popular Endomondo by Under Armour has been in your area but that route planning and ride-recording service is to be retired by the end of the year and replaced with a terrible MapMyRun service. Since all my rides have been recorded to Endomondo, I found the SyncMyTracks smartphone app and was able to gradually export & import all my rides from Endomondo to Strava.
I'm not happy with Strava.
Pros:
This is a nice feature of Strava indeed.
Cons:
I had a look at RideWithGPS. For $80 per annum, the system looks like it has almost everything I might need (Strava Premium is $60 per year). What about connectivity with e-bikes? Does the RWGPS understand what "e-bike" is? No, it doesn't.
I like RWGPS. Here, I have found my maximum speed was 51.7 km (downhill) and the maximum ascent was 13.5%: It was the hardest long ascent I ever rode on my Vado (48-46 gearing, full Turbo mode).
I decidedly prefer RWGPS to Strava. Here, I found I could easily climb up a 17.5% incline with my Trance E+ and achieved max speed of 59.3 km/h on a descent. RWGPS produces tons of useful ride data, only it doesn't work with advanced e-bike or a smartwatch.
I'm sure many of you have had experiences with both systems (and maybe other systems as well). Speak up!
Pros:
- Many premium e-bikes (ones equipped with Bluetooth or ANT+ capability) can export rides to Strava. Same with sports devices such as Garmin, etc.
- Probably the largest cycling community in the world uses Strava
- The system understands what "E-Bike" is, to differentiate traditional and electrically assisted rides (I like it)
- You can maintain the list of your bikes and calculate how much each of your bikes was ridden.
- It works, and the Auto-Pause capability seems to work adequately if you use Strava as a standalone, ride-recording app.
Cons:
- The Activity List cannot be easily navigated (say, you have 15 pages of workouts, and you need to click 14 times to get to the last page)
- There's no global way to edit your workouts. For example, you have mistakenly assigned 123 rides to some bike but want to re-assign them to another one: You cannot see at a glance what bike was ridden for a given workout, so you have to go through a big list of your rides, identify the wrong ones, and make 123 edits
- The activity search is limited. If you are trying to find your E-Bike rides, it is doable. If you however, look for "Rides" (traditional), Strava shows both your traditional and assisted rides. No way to just search for traditional ones.
- No chance to select several workouts and delete them
- The Personal Heat Map doesn't work for E-Bikes (why?!)
- No possibility to Export the Activity List to, e.g., Excel for further analysis
- You cannot clean up your rides. For instance, Strava got your ride wrong. You cannot fix it! (It is a measure to prevent competing cyclists against cheating; nothing is perfect in this world, though)
- No way to merge several rides of the same day
- No route planning
- No turn-by-turn navigation
