Help! Battery Full-Display shows empty-won't turn on!
smtara
I have a Pro-connect Kalkhoff Impluse 9 based on a 11ah 36v battery. A couple of days ago, I took my bike, turned on the pedelec, and came across the empty battery icon (as shown in attached image) despite the fact that my battery was full. (Battery is a 2014 battery but with more than 80 percent remained capacity and less than 20 cycles of charge out of 1100 cycles (according the factory-claimed capacity)).
Below is the list of what have done so far:
1- I took off the battery and let it charge to the balance point (green light) and put it back. Another time, I let it be on charger for few days, as some people had suggested for similar cases.
2- I checked all the connectors for loose connection.
3- I measured the voltage output of the battery and it was 42v which seems good.
4- I took the battery to a lab, and let it checked by a technician. All cells were fine with the right Amp and Volt. The only variation was 10 percent difference between some cells.
5- I tried to ride the bike several times and see if it understands my misery and come back with no reason!
All failed!
I am starving for any helpful advice, please!
This is simliar to the problem I'm having. Battery itself reads full but doesn't like up the display or connect at all. Did you get a solution? I read it might be the BMS switch but would have to open the battery to reset. ideas?
