HI All,
I have been using the Garmin Edge 1030 with my TV 4.0 since I got it and one of the most useful fields on the Garmin is Travel Range. It takes into account the battery charge and speed setting and gives a fairly accurate estimate of the range remaining. Well my bike just came back from it's second warranty motor change and they also updated all the software on the bike. When I first turned on the Garmin it didn't recognize the bike so I had to re-pair the new motor with the Garmin as a new sensor. Everything is working fine BUT there is an arbitrary distance (.62 miles if it matters) in the Travel Range field. I've gone through all the fixes on the Garmin and I agree with their tech support that since the Travel Range field goes blank when the bike is turned off that the problem is probably bad data from the bike. Any ideas or suggestions?
I'm looking at this in computer-terms and it seems like if there were some way to "clear the cache" or turn this particular channel off then on that it might clear this bad data. Could be all wrong though. . .
Thanks
Eric
Thanks
Eric
