Tom@WashDC
- USA
- City
- Loudoun County, VA.
I did that at first. Then I changed out the freewheel hub to a cassette hub and went with an 11-42T. Much nicer. 42T Chainring on the front.
Are the mks dd-7 folding pedals any longer than the stock pedals when extended or folded? I have wide feet and want a folding pedal a little longer.just got the 11-34 freewheel change and also changed the pedals to the mks fd-7 folding pedals and both work great---WHAT A DIFFERENCE!!!! Our local bicycle shop charged me 15$ to change freewheel, pedals, adjust brakes and basic tuneup. Same shop just converted my wife's suncycle trike to electic with even a reverse gear.Cant wait for spring here in michigan-snow freezing rain tomorrow but got to ride at 38 degrees yesterday. I would have to say changing seatpost,freewheel and pedals are best three mods imho.
I just bought a 2.0 in February 2022 and there is no washer to remove. They now supply a beefier freewheel with no washer. My conversion went perfectly and there was no washer to remove.I know when my son upgraded the Freewheel to 11-34 the original chain was a little taught. He has since purchased a new chain and has made the fit better. I agree to watch XP You Tube vids and you will have no problem on the switch out. Yeah, and don't forget to not put back on the washer. The new freewheel is only about 30 bucks and the freewheel tool is another 10 bucks...
I bought the cheaper one and it worked fine.About to change out my 14-28 for a 11-34 freewheel on my Lectric XP. Dumb question first: on Amazon there are these two listings:
which is the Drift Maniac DNP e-bike freewheel for $39.71
and
which is the Drift Maniac E-bike Freewheel for $29.61
Reviews seem to suggest either one will work on my Lectirc XP
So my dumb question is WHICH should I order, with the price NOT being an issue?
The freewheel change shouldn't have affected the disc brake spacing/centering. My bet is you have an issue with the washer placement between the hub and the frame on the disc side.Greetings from a newbie. Well, after research on the forum and elsewhere, I got the Drift Maniac 11-34 freewheel and the tool through Amazon. The exchange went smoothly, though I did not find the washer I was expecting to. After reassembly, the brake disc seems to be about 1/32" or so out of alignment with the brake assembly. I plan to disassemble the whole thing later today to see what, if anything I might've missed.
Anybody else familiar with my conundrum? I'm hoping I missed something fundamental which will reveal itself, but not overly confident at this point.
@NH Old Man, Can you flip the bike and photograph it? Put a white piece of paper on the floor under the caliper, so we can see the left/right gaps. Thanks. I just used this freewheel. It required a long cage derailleur. Even with that the derailleur rubs 1 when in 2 because the difference is so large.Thanks AHicks! It'll be later today before I get to it. Ill let you know what I find.
Many derailleurs such as a stock Tourney will not be able to hit the 34. They just do not have the reach. The jockey wheel will ride on the cog, not clear it. I agree that adjusting the brakes is easy. It could be just that the skewer is over tightened or not aligned.11-34 to work with the stock derailuier
So there is no advantage for speed only hill climbOne is the 34-t. It is the lowest for climbing. It is closest to the center of the bike. 11-t is the fastest on the flats. It is furthest to the right and is seventh gear.
If you already have an 11t small gear in back, and you want to be able to go faster (stay up with the pedals easier) when pedaling, l would suggest you look into a front gear with more teeth. Caveat being there can be clearance issues, and there are a couple of different sizes, so make sure you eyeball YOUR bike closely to prevent mistakes.So there is no advantage for speed only hill climb
Makes more sense to me I don't have mountain to climb I'm in Minnesota and still haven't been to mount minnyiowaIf you already have an 11t small gear in back, and you want to be able to go faster (stay up with the pedals easier) when pedaling, l would suggest you look into a front gear with more teeth. Caveat being there can be clearance issues, and there are a couple of different sizes, so make sure you eyeball YOUR bike closely to prevent mistakes.
Going from a 44-46t to a 49-52t in front is like picking up an extra gear.....
