Automated Safety Destroys Critical Decision-Making Skills
Time and again I see comments in support of software locked speed limits in e-bikes as a common safety measure.
Psychology begs to differ. Similarly to the way leg muscles atrophy when they aren't used, reduced exercise of critical judgment making results in reduced ability. When the bike takes control of speed, judgment critical to speed awareness is eroded. When that guy blows past you full speed on a narrow trail, one reason is that he has surrendered his own judgment to the bike to make those speed/safety decisions for him. In contrast, a biker who has to do the work of watching his speed limit is more situationally aware of and constantly making decisions about road conditions. Why make decisions when the bureaucrats have made them for you because you're too incompetent to observe a speed limit? Here is a psychological briefing on the matter that can be used at a professional level to make the point that the more automation we have in our lives the less able we are to exercise our own good judgment.
MEMORANDUM: THE COGNITIVE COST OF AUTOMATED REGULATION
TO:
Interested Stakeholders / Safety Policy Review
DATE:
SUBJECT:
The Paradox of Competence Decay in Firmware-Limited Mobility
I. EXECUTIVE SUMMARY
The current trend toward software-based speed regulation in personal electric mobility devices—specifically electric bicycles—is framed as a safety measure. However, psychological and ergonomic evidence suggests that these measures induce "Competence Decay." By automating speed decisions, we are shifting the rider from an active operator to a passive monitor, ultimately weakening the situational awareness and manual reflexes required to navigate public roads safely.
II. THE PSYCHOLOGY OF AUTOMATION BIAS
The primary danger of firmware-enforced speed limits is the phenomenon known as Automation Bias. Research in human-computer interaction and aviation psychology consistently shows that when a system provides a "safety net," human operators significantly reduce their own vigilance.
  • The Vigilance Decrement: As identified in classic human factors research, when an operator's role is reduced to monitoring rather than performing, their ability to detect anomalies drops precipitously (Warm, Parasuraman, & Matthews, 2008).
  • The "Nanny" Effect: When an e-bike’s firmware intervenes to cap speed, the rider stops internalizing the speed-environment relationship. They are no longer "reading" the traffic or the road; they are waiting for the software to signal the boundary. This removes the essential "feedback loop" between the human brain and the physical environment.
III. SKILL ATROPHY AND OVER-RELIANCE
The long-term cognitive consequence of this technological "coddling" is the atrophy of critical motor and decision-making skills.
  • The Transferability Crisis: We are observing a parallel to the transition to autonomous vehicles. Studies on "automation-induced loss of skill" demonstrate that drivers who grow accustomed to automated cruise control and braking exhibit slower reaction times when forced to take manual control (Endsley & Kiris, 1995).
  • The Illusion of Safety: By artificially capping performance, manufacturers create a rider base that is conditioned to perform within a narrow, "governed" set of variables. When the rider encounters a real-world scenario that falls outside the firmware’s parameters—such as an emergency obstacle—they lack the refined instincts to manage the bike’s momentum manually. They have been "trained" to be passengers in their own transport.
IV. THE DANGER OF "DE-SKILLED" RIDERS
The push for uniform, firmware-enforced speed limits creates a false sense of security that masks a decline in actual rider capability.
  1. Reduced Situational Awareness: Because the bike "takes care" of the top speed, the rider is less likely to actively scan for road conditions, as they assume the hardware will prevent them from reaching "dangerous" speeds.
  2. Increased Risk of "Surprise" Failures: A rider who has never learned to manage a high-torque or high-speed input manually is unprepared for the moment the software fails or is overridden by environmental conditions (e.g., downhill momentum).
V. CONCLUSION
From a psychological standpoint, the most effective safety feature is a competent, engaged operator. Any regulatory system that incentivizes the reduction of the rider's active role is inherently counterproductive. By automating the safety threshold, we are systematically disabling the rider’s ability to function as a self-sufficient operator.
We are trading individual competence for collective mediocrity—a trade-off that, in the complex environment of public roads, likely increases the risk of accidents rather than mitigating them.
REFERENCES
  • Endsley, M. R., & Kiris, E. O. (1995). The out-of-the-loop performance problem and level of control in automation. Human Factors.
  • Warm, J. S., Parasuraman, R., & Matthews, G. (2008). Vigilance requires hard mental work and is stressful. Human Factors.
  • Parasuraman, R., & Manzey, D. H. (2010). Complacency and Bias in Human Use of Automation. Human Factors.
We do NOT want to train kids from a young age that the bike is "safe" because it limits their speed for them.
The memorandum is also attached in PDF form.
  • THE COGNITIVE COST OF AUTOMATED REGULATION.pdf
Automated Safety Destroys Critical Decision-Making Skills​
So allowing high speed bicycles improves them? What absolute nonsense. Get off the soap box already.
My but you look awfully impressive inventing that strawman of "high-speed."
You realize when you make up another person's position and then destroy that invented position that you are merely losing an argument with yourself, right?
Please quote where I said "high speed" anything and clearly define what your clear understanding of a "high speed bicycle" is.
Fruitful discussion is not possible where someone hides behind making things up and loosely defined categories.
Is a bicycle "high-speed if it can go 21 miles an hour on the motor alone? That might be absolute nonsense.
