kevinmccune
- USA
"[England swings like a pendulum too,Fathers on bicycles,2x2]you can get your cardio in( or use "door dash" or similar)
I seem to recall them in Worcester MA in the 1950s.Rotary is a NY/NJ/New England thing. In NJ, some have signs in the middle that say "ROTARY". In MA, they seem to be the universal solution for intersections. Whenever a busy intersection gets redesigned here, they put a rotary in its place.
Couldn't they have just changed the laws instead of removing the circles?Actually the rules for traffic circles back in ancient times was quite different and that's why there were higher accident rates.
The biggest thing was those antediluvian traffic circles had the rule that cars entering the circle had right-of-way, while the modern equivalent gave priority to vehicles already in the circle.
You can't pump your own gas in NJ either.They did remove them in NJ. Then they made the law that you could not make a right after stopping at a red light. That is as dumb as the laws that you cannot self-serve gas in MA and OR. Only a trained professional can pump gas.
They could have, but the change in the laws seemed to have happened decades after the traffic circles were removed.Couldn't they have just changed the laws instead of removing the circles?
... except that charging overnight is typical for 90 percent of use cases and that is, everywhere, a time when we aren't using very much electricity. And since the structure of the grid is determined largely by peak load, you won't need to change the grid very much to allow ev charging at large scales.Of course everyone plugging in for a nightly topup is going to push off peak into peak.
