Does original DeHawk battery pack support 4A?
-sandro-
I can't find definitive data, the battery has no input/output data on it. I have a stock 2019 624Wh battery pack that came with the MCM Moscow standard. Do you know if the case/BMS supports 4A? The battery back should have no issue being way below 1C, the issue is that whole package.
I've got an ET.CYCLE T1000 which I thought had the same battery as your Moscow, so I did some research,..
My ET.CYCLE is also available as a folder, the F1000.
The folder uses the DeHawk charger, which appears to have a different connector, but the chargers are virtually identical.
This is what NCM shows as the battery for the Moscow,..
My 1000 WH battery only has a 3 amp charger. My 1200 WH battery has a 4 amp charger, and the charging port starts getting kinda hot at four amps. Your connector might be able to handle 4 amps better, but I don't think that it's a good idea.
Unless it's really important to you to charge faster, then a slower charge is always better especially with your 7 yr old battery.
You'll wear it out a lot quicker with a faster charge, and it may not be safe?
This is my battery and charger,..
The battery has the same i5 labeling as your DeHawk. (Whatever that means?)
Thank you, it's more about the casing and plugs I think. For the battery shouldn't even matter the difference between 2A and 4A.
Casing is a non issue.... It's the connector and BMS charge rating.
That said unless charge time is an issue, I would charge at 2A. Less heat and stress on the battery is always a best practice.
