I can see that next winter's project might be a drivetrain upgrade. Going with the higher-level components of the 5.0 would probably be the easiest, as I'm not looking for any changes regarding gear ratios. …
those sunrace cassettes are not great. very heavy and lacking the sophisticated ramping of the sram or shimano stuff.
personally i’d go with one of the AXS upgrade kits, reasonably priced and no more futzing with the cable, the cable getting stretched or worn or frayed. game changer for me. not sure if they have one with a cassette that matches the gearing you’ve got or if you’ll have to mix and match.
Rode up to the Calavera volcano overlook again with friend DW. He was on a Trek Verve+, not sure which one.
Beautiful day, great scenery intensely green from recent rain, good company, good workout, and best of all, an SL 1 to enjoy it all on.
Became aware of my motor noise on a steep climb in ECO. Came right alongside DW and couldn't hear his Bosch motor at all.
But here's the thing: After 17 months and 3200 mi, that motor noise is absolutely the ONLY thing I'd change about this bike. And most of the time, I don't even notice.
Otherwise, the SL 1's the perfect bike for me and my terrain. Very grateful to the many EBR members who encouraged me to take the lightweight, low-power, low-torque plunge.
What's your definition of "reasonably priced"? I think I'll have some other compatibility issues that I'd have to think through no matter what I do. The 4.0 is an 11-speed and, just as an example, I'm not sure about the availability of a compatible chainring that fits the OEM crankset with its 104mm BCD.
In any case, I think I need to get out there and ride what I've got for a while before overthinking everything.
definitely get some miles on it before thinking too much about upgrades!
the 12 speed nx cassette (11-50) fits a standard shimano freehub, ought to be plug and play. heavy piece but solid and a great range. its around $90. chainrings are the same between 11 and 12 in this case, lots to choose from.
the shifter and rd kit are more than I remembered though - around $550 - so you may be right about “reasonably priced” 😈
personally the difference between 11 and 12 speed never meant that much to me, but I do really like electronic shifting.
Not used my Vado SL 5.0 since December as I damaged my leg quite badly and cycling and walking was out for long time. The bike was stored in the house for the cold snap and never left its hiding place till yesterday when I went for a gentle ride to the shops, I was glad of the motor that's for sure.
I mentioned a rattle last year that I never diagnosed, well now it is just horrible so I will have to book a service. Might have to be April though as replacing an aging Macbook is first priority and the SL service is likely to be costly - new tires and chain for sure but no doubt other components as well.
I am wondering if the new Pathfinder TLR in a 45 will fit?
AI tells me that it is pretty much the same size as the 2Bliss Pros in a 42 that I have now . I have no rack on my bike and the front tyre has about 3mm of clearance at the sides. The rear tyre has about 5mm of clearance - both inflated to 45psi
I wouldn't recommend that. Even if the tyre fit (especially the rear), you might lose any clearance for the mud and debris removal.
Curious, what's your motivation for going from 42 to 45 mm tires?
I'm running the tubeless Pathfinder Pro 38s on my SL 1 5.0. Love riding gravel on this bike when I can, but most rides from home are on pavement.
The only reason I'd consider going wider than 38 mm would be for safer braking on hardpack descents. These tend to have a very thin veneer of loose sand in this coastal environment.
Result: Plenty of 10% or steeper hardpack trails here that I'm strong enough to climb but too chicken to descend.
It is just because they have changed their tire sizes and replaced the 38 with a 40 and the 42 with the 45.
I thought the 42 were so much better than the 38 standard tires but I guess that could have been down to the compound and that I went from tubed to tubeless.
I guess the 40s are the safer bet.
I have Pirelli gravel tires in 45 on my Vado SL 4.0 and they fit fine with plenty of clearance.
They have a noticeably softer and more compliant ride than the 38 Pathfinders.
I just installed them about 6 rides ago and haven't been able to fully test them out on the dirt and gravel that I normally ride on since those trails are too soft and mushy right now.
I agree. I had 40mm Pathfinder TLRs (because the Sworks 42 mm pathfinders seem to be discontinued). Had really bad micropore sealant weeping on both sidewalls on one of the tires. Seems to have been a quality issue with at least the early batches of these tires according to other users reports I've read. Regardless, when it was time to replace, I also switched to Pirelli Cinturato Gravel H 45 mm. I agree they do seem much more compliant. I do note that Pirelli has also recently introduced newer 50mm versions that would fit on my fenderless. Pretty happy with the 45's but might switch to the 50's when it's time.
Thanks! My SL 1 5.0 EQ has fenders. Are you using the Pirelli 45s with or without fenders? Same question for @Cycologist .
My 42 mm Specialized Tracers or Rhombus tyres were preventing installing any kind of fender at the rear, size M frame. I wonder what the measured width of the Pirelli 45 actually is.
Which Pirelli model? A little more compliance does sound tempting when the 38s are done.
Again, as often tyre widths come up here, my WTB Byways 44mm are plush and nicely fast rolling and fit under SKS Speedrockers comfortably. Currently swapped out for winter GravelKings SK 43mm as the roads after 2 full months of rain are potholed soup...
I don't have fenders, but I'm guessing the Pirelli 45's wouldn't clear your bike. My SL 1 4.0 EQ had fenders and the 42 mm Swork Pathfinders would hit the bolt head for the rear fender mount - the front was ok. I ended up using a regular 38 mm Pathfinder on the rear.
