Light vs regular full suspension ebikes
Johnny
Recently, I’ve been thinking about getting another full suspension eMTB. Some of the newer models I’ve seen look really appealing. Although the prices seems to have increased a lot, the average offering seems to come with higher end components and I see a lot of CF frames.
While researching more traditional full powered eMTBs like those with Bosch CX(gen 5 seems decent) or Shimano EP8/EP801(old but there are a few good deals on these) motors, I realized there’s now a growing category of lighter eMTBs. These bikes pair less powerful motors with carbon frames and seem to offer a very different riding experience.
Several of the models I looked at use TQ HPR50 motors. They’re very light and visually, almost indistinguishable from regular mtbs. The trek I saw took me a moment before realizing that it was an electric bike. I’m curious to hear your opinion on this type of bikes compared to the regular ones.
I would be interested in something I can easily hop on, ride leisurely on hills, light trails, and that feels closer to a regular bike especially when the motor is turned off. Additionally, many of the trails in my area have a no–e-bike policy. I was wondering whether riding a TQ50 or similar light eMTB with the motor turned off would generally be acceptable on those trails.
I don't ride an EMTB but we sell a lot of them at the shop. Mondraker Dune, Orbea Wild, Cannondale Moterra. All Bosch. Personally, I have two electric bikes, a full power Cannondale Tesoro, with a Bosch 85Nm motor, and a Pinarello Nytro E5 Allroad, which is a "commuter" bike built on a gravel frame, that has the TQ HPR50. They are completely different in weight and power.
The Cannondale, even on Eco, will pull you along once you get going. Crank up the assist, and it's clearly an electric bike without a throttle. It's also around 50 pounds, and a hardtail. It's a bit too much bike for me. The Pinarello is around 32 pounds, no suspension. You can get EMTBs with HPR50's close to that weight. The TQ is very different. Only on assist level High do you get that e-bike feeling. At normal assist levels, it's like riding in a tailwind. It's very quiet and very subtle. I ride it a lot with the assist off, because you can. It's light, fast, and handles like an analog bike. You may see some reports on the internet of HPR50 motors failing, or reducing power due to overheating. The main failure is the sprag clutch, which is what connects the crank to the motor. TQ has been very good at replacing them. The failures have mostly been in EMTB's ridden very hard for their entire battery range. To address this, TQ introduced the HPR60, which has external cooling fins, and updated software to limit power. The HPR60 can be retrofitted to most HPR50 bikes if needed.
The big kahuna in EMTB motors today is the DJI Avinox. It's a full power 105Nm mid drive motor with a smaller, lighter battery. DJI has found a way to increase efficiency to get reasonable range while having big power on tap in a lighter footprint. You can get it in the AMFLOW, and about a dozen smaller, some boutique, manufacturers. At least one big name brand will have one in their bike this spring. I'm not allowed to say who that is.
Excellent information, thank you. On my bikes with the older Bosch CX, I rarely used anything beyond Eco mode (occasionally Tour, and almost never Turbo; Turbo always felt more like a throttle to me) until I eventually sold them. While Eco was sufficient most of the time, I never really enjoyed riding those bikes without assistance. That’s one of the reasons these newer light bikes caught my attention. When I lifted one in the shop, I was genuinely surprised, it was quoted at under 40 lbs, around 38–39 lbs, which is impressive considering the beefy suspension components and how good it looks.
Oh, well even with the sales I'd rather not put 4k on a bike to later change the motor but thanks for the information.
Yes, I’ve seen the reviews and was very interested in the DJI motors. Not only does the hardware look excellent, but the ecosystem also appears to be more open and flexible compared to Bosch. I’m not looking for more power per se, but on the road I’d be happy to use the bike as a Class 3, and then switch to Class 1 on trails which seems possible with this system. The main issue, as you mentioned, is that AMFLOW is currently the only brand using that motor. If you’re saying that more brands will be coming out with bikes using it, that’s definitely good to hear.
By the way, among full-power bikes I really liked the Cannondale Moterra. The model I found has a carbon frame, and I’m wondering how durable those frames are. I do all my own bike maintenance, but I’m a bit cautious when it comes to carbon-fiber frames.
There are about a dozen small manufacturers that build EMTB's around the Avinox today, just not one major manufacturer. As for carbon frames, you're not going to get the light weight and ride quality you want without one. Do they break? Yes. Can they be repaired? Most of the time.
I would not let internet reports on the TQ system scare you away from the platform. B*tching reigns supreme on the internet. From what you have said, it's a great fit for your riding style. Check out the Yeti MTe. HPR60, 38 pounds. Absolutely beautiful in person.
Thank you. CF made sense on those really lightweight bikes. I’ll check a few other shops to see what they have, and I’ll also take a look at the Yeti.
What’s your take on carbon fiber full-power eMTBs? It seems like the market has shifted toward more expensive bikes with carbon frames even in the heavier(50+lbs), full-power category, but I’m skeptical about how much advantage carbon really offers on bikes like that.
My take is the same. I would not buy a no-name carbon framed EMTB no matter what power level the motor is. I would absolutely buy a carbon framed bike from a major manufacturer. Most have frame replacement programs that protect you as long as you own the bike. We had a guy with a Moterra come in the other day who had a bad wreck on the trail. He's pretty banged up and won't be riding for a while. The bike was as bad off as him. He tore the NDS rear dropout completely off. The rear wheel was dangling from the other dropout. One call to Cannondale, and he's getting a new frame.
Even though full suspension MTB's ride quality is mainly about the suspension, the frame does still play a part in the ride. Lighter weight certainly does.
Crash replacement is a program, there's nothing to deny. They don't care how the frame was damaged, it's an offer for replacement at a fraction of replacement cost. If there is a trend of these kinds of failures, the replacement may be done at no cost under a goodwill program.
Warranty claims are something else altogether. Unless it's a component failure under the component manufacturer's warranty, the bike manufacturer has to eat the cost. Success is very dependent on your dealer and if they are willing to go to bat for you. A good shop will assume the claim is a warrantied thing and will fight for it from the jump. Other shops will represent the manufacturer and deny the claim without even trying to contact them. Those are the dealers that get the complaints.
I just want to be sure that any defects or cracks that develop under normal/mild riding conditions would be covered not crashes.
I’m also curious about your recommended approach to maintaining these frames. I handle most of my own maintenance and always follow torque specifications, but carbon frames still make me a bit nervous.
By the way, where is your shop located?
Who’s paying to swap all the parts over to the new frame? The owner, or Cannondale?
Id be cautious of buying a Mtb or Emtb with a carbon frame. I drop and fall with aluminum framed Levo all the time. I’d be freaked out if it was a carbon frame.
"Crash Replacement" is a generic term. Nobody's going to ask you for a police report or an official's occurrence report.
There's really nothing to maintain on a carbon frame versus any other material. You must use carbon paste where needed, and be wary of torque values recommended by the manufacturer. I would also install a chainstay guard on the drive side if the manufacturer hasn't done that already. I keep it clean, and use a spray wax like Bike Lust after a good cleaning.
I don't own a shop. I work at one part time in Massachusetts, USA.
It depends on the claim. If the bike is under the general warranty, usually the manufacturer. If not, they may still cover it under goodwill. If the bike was purchased from the shop that's servicing it, there is also the possibility of shop owner goodwill.
From my perspective, you can look at a bike in one of two ways: as a tool, or as jewelry. If you're in the latter camp, don't buy anything that you'd be afraid to break.
As for buying an e-bike with a carbon frame from an unknown manufacturer, I would be wary. Not that I'd be afraid to break it, rather what would happen if I did.
There is yet another factor, which is often overlooked: the lower system weight limit for CF bikes. Combined with (possibly) carbon wheels and fewer spokes, the thing is not for heavier riders.
Now, the weight gain between the CF frame and an alloy one is 1 kg (around 2 lbs). While it makes sense for a lightweight rider and low power small battery e-bike, the weight difference on a full power e-MTB ridden by a heavy person is not worth the cost.
A CF bike/e-bike is jewelry. It is different when the racing team sponsor buys a fleet of performance bikes, and when an individual buys themselves a piece of jewelry.
I was tempted to buy myself a lighweight CF e-bike but also considered both my heavy body weight and similar tendencies as yours, @Extreme1. It is different when my below 70 kg brother rides an alloy gravel bike with a CF fork and myself weighing over 100 kg :) Still, early into the ownership of that bike, a stone was shot from under a wheel of a gravel bike nearby; the stone hit the fork of my brother's bike, which required a complicated repair. Now, same would make no harm on an alloy fork (perhaps some scratched paint, that's it).
Weight limits are a consideration for any kind of e-bike. Carbon wheels with lower spoke count can be stronger than aluminum rimmed wheels.
It's more than the weight, it's how they ride. Ask your brother why he decided to repair his carbon fork rather than replace it with aluminum.
That's your perspective, not a fact. I purchased all of my carbon race frames myself with no sponsor support. Delta Airlines broke one of them and it was replaced under crash replacement. All I lost was a lot of history and memories.
It was because he wanted to retain the original part; and was talented enough to do the repair himself. (He has no money to juggle with the components as he would please).
CF can be stronger than steel but it is brittle if hit from a wrong direction.
I'd like to hear a story of an alloy bike with its frame broken by an airline during the transport.
Now, regarding the structural weight limits:
Levo Comp Carbon G4: 125 kg
Levo Comp Alloy G4: 136 kg.
My body weight (clad for the summer) is 105 kg
Cargo weight (hydration pack, tools, snacks): 5 kg
Levo Comp Carbon G4 weight with pedals 25 kg. Total system weight: 135 kg (well above the limit)
Levo Comp Alloy G4 weight with pedals 26 kg. Total system weight: 136 kg (at the limit).
So, you Stomp say a carbon fibre e-bike is that strong it could carry a heavy person without any worries?
I wouldn't even discuss the wheels after the rear alloy 28 spoke wheel in my Vado got completely bent after two years of heavy riding. I even don't want to think what would have happened to an expensive carbon wheel in my scenario.
Replaced with a custom built wheel, DT Swiss components, 32 spokes.
They don't break, they bend to the point that the frame cannot be realigned.
If you hit an aluminum frame top tube with a 2 pound sledge, you'll dent it and potentially knock it permanently out of alignment. This cannot be fixed. If you do the same with a carbon frame, you'll break it, and it most likely can be fixed by a professional. What's the difference? This is a red herring argument.
No, I said that you need to respect the weight limits as all bikes have them. In your case, that carbon bike is not for you, but another one certainly could be.
That's a tacoed wheel. This usually happens because the wheel had been well used, spoke tension was not properly maintained, and it went through some kind of trauma. As wheels age, no matter what rim type they have, the spokes need to be maintained.
Carbon rims don't bend like that.
