Broken motor gear for acbest 27.5 48vlt 1200watt e bike
Mickster69
Im looking for 18t- 39t gear i can only find 18t - 40t gear for bafang motor. I have a unbranded no name generic brushless motor, can anyone help me out with this problem
That's a tough part to look for. Popular motors like AKM and Bafang have parts, but the no name guys are like orphans,
I see you marked and counted them, and it looks like 39T, Count the other ones to be sure, Post on a technical nuts and bolts forum like endless sphere too,
AKM 95RX motor has 40 t - 18 t nylon gears if say dimensions are the same or close and have 6mm bearing, and has the same left tilt like my 39 t, would you or anyone else no if the 40t - 18t work as replacement gears in my 48vlt 1200watt brushless hub motor?
Im a newbie at this gear and hub motor stuff, as you can see all 3 gears have a few broken teeth almost all on the 39t gear, please point me into the right direction
It's probably going to be easier just to replace the motor. You can buy a wheel with the motor already laced in.
No it's not easier to just get another motor. Planetary gears with another clutch assembly is no more than $50.00 and they are super easy to install. A new motor is gonna be at least 200.00
Lol! They are not easy to install if you can't find replacement gears for the motor...
