Hi all,
I have a 2021 Turbo SL 5.0 which I am very happy with.  However, the new Turbo Vado SL 2 6.0 Carbon looks pretty damned good! If anyone here has upgraded from the 5.0 to the 6.0, I'd be interested in your comments. I know the newer motor is more powerful, and the newer battery is larger, but I'm curious about the ride and whether the 6.0 feels substantially different.
				There's no other e-bike out there with ride quality, range, and power like this, at a weight that's light enough to carry. The Turbo Vado SL 5.0 is best...
					www.specialized.com
				Nothing delivers more power, speed, and range at such lightweight than Turbo Vado SL 2 Carbon. It’s a premium, performance machine carefully engineered ...
					www.specialized.com
Thanks for your thoughts.
John
Hi John,
I did the move from the SL 4.0 to the SL2 6.0 (both EQ) a couple of months ago.
Where it excels the 4.0 and 5.0:
- the engine / battery is more powerful. I still have the 4.0 and when we ride together on both bikes, then the turbo mode on the 4.0 approximately equals the sport mode on the 6.0, so we can ride together at same speed / effort.
- battery is bigger, so lasts equally long with more power. Did commute today to city centre and back in turbo mode (2 x 15 km, 36-38 minutes ride each). 71% of battery remaining
- the display is nice. Very readable, suggest also best gear for your pace
- Rear light works as automatic stop light
- More sturdy rack
- Tires are broader and have more profile, means you get a softer ride and are less prone to flat tires in terrain
- more gears to choose from
- possibility to remotely update the firmware
- integrated Findme Apple functionality and a bike alarm when not unlocked through the app (although rather low volume but at least it prevents activating the bikes display and engine)
- engine is more silent
- Compared to the 4.0 of course the future shock
The disadvantages:
- obviously the price. Costs quite a fortune
- Does not look as slim at the previous model. You can see it's an e-bike
- Carbon has lower weight limits for rider + luggage
- The battery and engine weight more. The carbon version does offset that extra weight, the alloy version obviously doesn't
- rack uses a different system. Had to change the adapter for all my bags to fit the new rack
- The matt finish of the painting attracts dust
Would I do the change again? Yes, the 6.0 is a great bike. The thing I probably miss most is the esthetics of the slim frame of the 4.0. The 4.0 (as the 5.0) is a bit of a stealth e-bike which not everybody recognizes it as such that easily. The 6.0 is lighter than a standard bike but due to the broader and more square frame it looks like an e-bike .
