OkinawaJapan
- Asia
Great write up.Posting in the Bafang forum as there is no MXUS forum, and this motor may be relevant to users of the Bafang geared hubs.
This is somewhat of a new motor, and limited information is available in english. Here is some information that may help. XF19R XF19R-FAT GDR19 FAT GDR19-FAT
2 versions of the motor exist, a 750w-1000 rated motor and 1200w-1500 rated motor. This is the highest rating of any geared hub motor, and also has the highest advertised maximum torque of 125nm as well as the highest rated voltage (48-60v rated) and the largest diameter core, and therefore appears to be the most powerful geared hub motor available.
I was told by Mxus import/export on Alibaba, the difference between the 2 motors is the 750w has 20H magnets, and 1200w has 25H magnets. This is the only difference I have been able to identify so far between the two. Not sure if copper fill is any different but would imagine it might be. However see the picture below, the copper fill looks quite nice (a significant amount of copper is stuffed in these larger diameter motors). See the photo below, the motor has a larger stator/rotor than previous generation geared motors, allowing more copper and a greater amount of torque due to leverage ratio.
I was told it is available in 4T and 5T configurations, with the 5T having 400rpm unloaded at 48v, and 4T having 500rpm unloaded at 48v.
Take a look at the clutch picture- you will notice it has 2 notches, where 2 feather/parallel/magnet keys can fit. The feather key slot is much larger than previous generation geared motors. This is perhaps why the motor can handle more torque. When running high torque on prior models the feather key would shear off, this model has a much stronger (longer) feather key, as well as feather keys on both sides, and appears it can withstand significantly more torque than previous motors. The gears appear to still be nylon, but of course can be upgraded.
Also attached is a hard to find dimensions diagram of the motor
What I like- Appears to have more copper, larger diameter, stronger axle/clutch, in comparison to previous motors.
Regarding purchasing- Very limited information is available on this for english speaking countries and only 1 or 2 sellers have this motor on Aliexpress, the cost is typically $400-450 or more. I ordered from Alibaba, and was able to acquire the motor much cheaper. Not only was it cheaper, I could choose between axle widths (175mm/190mm) and the turn count (4T/5T) as well as the wattage (750/1200). Lastly and most importantly the factory allows customization of the motor cable, I was able to have a factory installed L1019 MALE connector rather than an inferior Z916 or other. Alibaba also seemed more knowledgeable than any of the other limited sellers. Changzhou Mxus Imp.&Exp. Co., Ltd. on Alibaba if it helps anyone.
Hope this helps anyone that cannot find information about this motor. I will be testing this motor and add more information when I can in 30-60 days, comparing it against the next closest competitor the Bafang G062.
I think this is the link to the same one you bought? https://www.alibaba.com/product-detail/Electric-Gear-Rear-Drive-Snowmobile-48v_1601379396205.html
I also found another model on that reseller's alibaba webstore. Model GDR19-SR. Which is listed as a 1500w motor. Thoughts in comparison? Says it's a bit heavier.
Mxus High Power 48v 1500w Electric Bicycle Snow Fat Hub Motor - Buy Bicycle Electric Motor 1200w Hub Motor e-bike Motor Product on Alibaba.com
The wiring issues you saw concern me though. I'm not ready to rewire brand new hubs upon arrival. Even if better than a bafang. If they have things sorted out by now I'd be more likely to try one.
But if it's not easy to get working with a Grin Baserunner/Phaserunner L10 easily, then for me I'll probably go with a Bafang for now.
I don't see it in the Grin list even when choosing from all motors.
But I really like all the upgrades they've added to this motor. It has potential to outdo Bafang finally it seems. It would just need to catch on and get the wiring plug and play for the L1019 pinout if it still isn't already.
By the way guys. How are your motors doing since your last updates? @David Dye @Boosted
