Creo 2 Carbon Cranks
But can you send link to those DUB cranks that you say are very expensive, just for reference? Those force which I found also called DUB cranks, so it is confusing.
These are just the carbon crank arms for the Levo 2, but share the same fitment as the Creo 2. DUB refers to the spindle size (28.9mm I think). When looking for cranks, you must have 2 arms with no spindle attached, same as on the Creo 2
I see, so this are MTB one's, they for sure has wider Q factor. So actual situation is, that actually seems Specialized or any other brands like SRAM doesn't offer any kind of cranks specifically for Creo SL2, regardless of price.
I was using these as an example of what you are looking for, 2 separate arms with the DUB / BB30 interface to fit on to the motor spindle. I was not going to spend £500 on cranks when I could do the same for £120. My cheap carbon BB30's have been flawless for the last 1000 miles. The SRAM website is next to useless for Creo 2 parts
Question for those that have replaced the alloy arms with carbon, how noticeable the difference? I have a Creo 2 expert.
The carbon cranks are a fair bit lighter than the alloy ones. in the 175mm the alloy ones were 280g and the carbon ones about 170g. Although 100 odd grams a side does not sound much, done as a percentage, this is roughly a 65% drop on rotational mass. The carbon cranks do spin up quicker for sure. Not noticed any difference in stiffness or q factor
Had my LBS order a set from Specialized. They were $370 USD. Not sure how much of a difference they make but look great on my bike.
They will be much lighter than alloy ones, mine were 270g v 180g a side from memory. They spin up much quicker I find
Thought I'd report my experience. Found a new old stock Force Press fit 30 crankset. I'm a pretty good mechanic and I can tell you getting the lock tighted bolt out of the non-drive side crank arm was a challenge. It took lots of pounding with a rubber mallet to get it loose. I had the 10mm hex locked into my vise and pounded on the crank arm until I thought it might break. It did not break and the bolt finally came loose. Then the second step to remove the spindle also required some hard pounding. Got it done but not for the faint of heart.
Thought I'd report my experience. Found a new old stock Force Press fit 30 crankset. I'm a pretty good mechanic and I can tell you getting the lock tighted bolt out of the drive side crank arm was a challenge. It took lots of pounding with a rubber mallet to get it loose. I had the 10mm hex locked into my vise and pounded on the crank arm until I thought it might break. It did not break and the bolt finally came loose. Then the second step to remove the spindle also required some hard pounding. Got it done but not for the faint of heart.
The first time you do it, it is not for the faint hearted. I have done 3 of them now and the second two came out easy. Just knowing how heavy handed to be
Installed crank arms today on Creo 2. Quite the DIY project. Not sure I will ever notice the weight reduction but I am making my Creo 2 Comp lighter with crank arms and 1100 gram carbon wheels to replace the 2000 gram alloys. A gram here a gram there. What the heck?
I did notice the difference and found they were quicker to spin up. 200g is a nice little gram saving in my book
1kg total is very significant weight savings.
Edit I missed the wheel change. I think the total is really under 400g for the cranks and frequently they are changing length too so it's a bit less. Somewhere I have the numbers for a Praxis 165mm alloy vs 165mm carbon but it was about 2.5oz per side or 142g total. The carbon 165mm cranks were an add on to a new 1.1 motor I had purchased from a third party.
there are lots of grams to be had. took +/- 5lb off my creo 1 :)
Curious how much that cost in $/gram and where you felt the most benefit — climbing, general responsiveness, etc.
as you might guess, i have that spreadsheet lol. looking back it was ±4lb apples to apples, there are a few things i've forgotten or don't have weights for like bottle cages, lights, bar tape, etc. the cost per gram ranges from less than a dollar a gram to $5 a gram, but the biggest difference was absolutely the rear wheel - total weight savings 467 grams, of which 190g was going from the stock sunrace cassette to a sram 10-42 and the rest is the wheel and tire. that's an entire pound of rotating mass - imagine pouring an entire 16oz soda bottle into your tire and hub, lol. and of course nice carbon wheels are better at reducing vibration and harsh bumps, and more aero. certainly the biggest possible difference, especially with tires of the correct width for the rim (in this case they were 32mm)
the next most noticeable as a combination was going from crazy heavy freerider pro shoes, platform pedals, and aluminum cranks to super light road shoes, speedplay pedals, and carbon cranks. total reduction almost 1.5lb! now imagine a 12 oz soda can attached to each foot, going around and around and around. of course the pedals don't go around as fast as the rear tire and the weight is much closer to the center of rotation, but still very noticeable, and of course being clipped in is a whole different feeling.
after the wheels the next biggest improvement in "feel" was the one piece alpinist carbon bar, 220g of weight reduction (good value today at around $1.3/g but i think at the time it was more expensive) but a really nice low-vibration feel and super sleek look for the front end, for a non-integrated-cable bike!
in the end the bike was nicer than the s-works version with the exception of the brifters and rear derailleur. upgrading those actually wouldn't have saved meaningful weight, but as you know i'm a huge fan of electronic shifting.
I purchased the Creo 2 Carbon Comp and this came with alloy cranks. On the Creo 1, the weight difference in the cranks was fairly minimal between alloy and carbon and I was expecting the same of the SRAM Dub cranks on the Creo 2. However, I found that the alloy SRAM cranks and weighty numbers at 260g a side. I priced up the SRAM carbon cranks and these are expensive. I found a set for £525 (but have seen then cheaper in USA at around $300.
However, I have found a extremely cheap way to get carbon cranks on the Creo 2 and save 200g. The SRAM BB30 cranks and the same interface as SRAM Dub. I picked up a set of SRAM Force Carbon cranks for £50, removed the spindle and they fit just fine. The only down side is the left side does not have a self extracting bolt, but how often do you take the left crank off?
So look at BB30 cranks with a bolt on spindle and make a big saving over the SRAM Dub ones and nice weight drop to.
how do you remove the side that does not have the self-extracting bolt should you need to do that?
A bit late to the party, but just wanted to say a massive thank you to the OP as I followed their advice and did exactly this mod/hack/upgrade to my recently purchased Creo 2. See attached pics. I calculated the weight saving at 164g.
In reply to the previous poster, I worked with an engineer friend to do this modification and before committing, we checked that it should be possible to use his crank-puller to remove the non-drive side crank if needed.
