Throttle and brake connectors
shauny2801
United Kingdom
Hi my throttle wire harness snapped of right before sealed joint so couldn't repair it so im looking for a replacement wire harness which has the 2 red connectors for brakes and one yellow for throttle. The problem i have is the cable from control box for these is a blue 4 pin connector the only ones I have an 8 pin to control box connection so don't know how I can work round this?
I think the only option is i can get another thumb throttle which has a 4 pin connector and get an extension to controller as im selling the bike anyway I just wanted the throttle working
I brought a new thumb throttle with the blue 4 pin connection connected it to controller cable tried it before putting it on bike but nothing! Don't understand why its not working unless its because brake sensor cables are disconnected
Shaun, can you get detailed information about the cabling from the manufacturer? Or it could be that your wiring got crimped / torn when the damage occurred...
Good luck with the repair.
So you illegally use a throttle in the UK ?
So any insurance you have if you bothered is not valid and if you should ever bee involved in an accident even NOT your fault good luck with the Police
It was just a clearance bike off ebay I just want throttle working for when I sell it I want to find out if you can cut 8 pin julet off end and wire on a 4 pin is this possible
You need to know the purpose of the pins/wires and how it connects to the controller.
In other words you need the controller wiring schematic and an understanding of how to possibly manipulate it for your needs.
No one here can answer your question without this information as well.
