I have an M2S All Terrain Ultra HT bike with the Bafang M620.  A few weeks ago I rode the bike for a few miles on a wet, grassy road while it was raining hard.  Then parked it under my covered porch when I got home.  The next day I had it in the bed of my truck while it drizzled all day.  The following day after a few miles it threw Error Code 12 on the display, "Fault with current sensor inside controller".  Tech support said it was likely caused from moisture issues and after drying out would be fine.  Several days parked beside my woodstove and no luck.  It would work one day for a few miles, then throw the code.  It did this for several days.  Since it was a muddy mess I knew I needed to wash it before diving into the issue further.  I washed it with a garden hose and now it will not turn on at all.  The status lights on top of the battery do not light up with a charged battery.  I pulled the battery and checked the 45amp fuse on top and it's good.  I did notice after it wouldn't turn on when rolling the bike backwards there is considerable resistance in the motor area.  I do not recall it being like that prior to washing it and not turning on.  Tech support is telling me to replace the controller because it's drawing current when it shouldn't.  Does this make sense?  I do not want to drop $125 throwing parts at it if it's not likely this is the problem.  Thanks for any input.
