Stefan Mikes
Gravel e-biker
- Europe
- City
- Mazovia, PL
Next: How does Mahle cheat about the x20 torque? Explaining again.
Mahle has never said the x20 hub drive motor had 55 Nm. The brand said:
They said: "Comparable to a 55 Nm Mid Drive". Source.
Let see what it actually means. The hub-drive motor propels the rear wheel directly. The mid-drive motor acts on the rear wheel via the drivetrain, so the torque at the rear wheel can be either amplified (MTB low gears) or reduced (high gears). Mahle has assumed the rider would ride at the 55/23 = 2.39 : 1 gearing. The large chainring on Scott Addict RC eRide Ultimate is 52T. Therefore, the selected cassette gear would be 52/2.39 = 22 teeth. It is a middle gear on a 11-34T cassette.
So far so good. Mahle has explained its reasoning. Now, let us assume you are climbing. Let us compare a mid-drive 50 Nm motor (TQ HPR 50) on a TREK Domane+ 6 SLR Pro. The chainring is 46T and let us assume the 22T cassette cog selected for the comparison. The gearing would be 46/22 = 2.09. The TQ motor offers max 47 Nm torque (300 W/6.28). The effective torque at the rear wheel would be 47 / 2.09 = 22.5 Nm.
A very interesting result! It looks Mahle has nailed it for a typical road riding scenario? Let us analyze a mountain climbing case then.
A TREK carbon Domane+ 6 rider may drop the gearing down to 46/36T = 1.277 gearing ratio. Now, the effective torque at the rear wheel is 47 Nm/1.277 = 36.8 Nm. Mahle x20 would provide 23 Nm, not more.
A TREK carbon Domane+ 6 rider may install a 2x 52/36T chainring and a front derailleur (it is in the specs). Now, the rider would downshift to 36T chainring and 36T cassette cog giving the gearing ratio of 1:1. The TQ HPR motor would give 47 Nm at the rear wheel while the x20 would stay at 23 Nm in this climbing scenario.
Moreover, hub-drive motors are poor climbers. As the e-bike speed drops, the hub-drive motor becomes inefficient. It delivers a little power/torque at low speed and overheats.
The Bottom Line
It is very easy to juggle with the numbers, Mahle! You have almost convinced me because your scenario was about riding on the flat, or on a soft incline. When it comes to serious climbs, you can shove your data where the sun don't shine
It is a good mid-drive motor for road e-bikes that shines.
The Bottom Line
