Can someone explain to me e-bike maintenance
Hi everyone,
Great topic! E-bike maintenance can seem overwhelming at first, but once you get into a routine, it’s pretty straightforward. I’ve been riding electric bikes for a while, and here’s what I’ve found to be essential:
1. Battery Maintenance
2. Chain & Drivetrain
3. Brakes
4. Tires & Suspension
5. General Checks
Would love to hear what everyone else does for maintenance! What's been your worst maintenance challenge yet?
just some random tips,
You could buy a "special" tool from an UK brand to be able to backpedal with a clutched mid-motor to clean/lube etc of the drive train. You could also use a cheaper and "better" solution and that would be a Wera Stubby or Hultafors Stubby bit holder tool. That dose a better job and you have a good tool to drag along a ride. Or just put a rubber sleeve around an Y-tool.
you would stick this tool in the chaingring bolt and use the cranck placed against this tool to backpedal and move the chain/cassette for cleaning.
Do not use a pressure washer on your bike, it will cause issues. (open door I know)
Clean your bike before working on it, than you already had your fingers and eyes around your bike so you already know what could be the issues to work on. And also a clean bike is easy to work on.
I do use polish wax to keep the bikes nice and clean, just be ware of the rotors....
Invest in a workstand, this really saves a lot of time and hassle, or workout a way to hoist you bike of the floor using a lift or system with hooks and rope/tension straps. For longer road trips I always bring a few tension straps to attach gear to my bike but also so I can work on a bike by hanging it in the air. Mostly used on other peoples bikes.... you can always find a spot to lift the bike, trees, door frame etc.
Replace any worn-out bolts.... to many times as a pro I had to get crappy bolts out of bikes...
Get a list of torque specs for your bike's bolts and use a torque wrench.
Cheers
I've had 3 e-bikes at once, but seemed to me that on 29 days a month, a stand would just be in my way. I don't even need a step stool to reach the rafters in my carport. That made suspension the obvious choice. I bought these.
For each end of the bike, I used 2, about 2 feet apart. Run a rope through one, run it under lift point on the bike, and tie it off on the other eye screw.
Now I needed a way to secure the bight, where it would hang out of the way and wouldn't come loose accidentally. These work fine.
When I'm not hanging a bike, I've got a couple of ropes neatly out of the way.
Torquing beyond the yield point will wear a bolt out. I've always torqued by feeling the elasticity in a fastener, occasionally checking with a torque wrench. That didn't work on the front axle of my Aventon because I couldn't feel the elasticity. I downloaded the specs. Many looked absurdly high. Often, they gave two figures. The second could be twice the first. Huh????
Apparently, American dealers wanted specs, so Aventon had somebody write down how many Nm it took to break loose various fasteners. That's not legitimate. They said 40 to 45 Nm for the M8 x 1 crank arm bolts. I knew that was far more than I applied by feel. Several youtube shows recommended using a torque wrench to apply about 45 Nm to M8 x 1 crank arm bolts when in fact they did it by feel.
All the modern bicycle bolts I remember have been class 8.8. In that class, an M8 x 1 takes 25 Nm, nor 45. Amazon has pages and pages of replacement M8 crank arm bolts. Maybe that's because so many are being damaged by following bicycle manufacturers' specs.
A set of ISO 2936 standard arm hex socket keys makes it simple. When a toolmaker designs a bicycle part, he'll specify a bolt with a socket for the size key designed for the required torque. I slowly pull the key tight until I'm at the maximum pressure I could comfortably maintain for 5 minutes.
  • ISO2936-Specifications.pdf
a few years ago a bigger tool brand had a test bench on the eurobike, to let bike-mechanics check their ability to determine if one could indeed gues the torque they use on a bolt. So they put a series of m5 and m6 bolts next to eachother wiht a torque measuring device underneath the setup. Using your discribed method you could fasten 5 bolts per size to check how close you could come to the bolt spec. Values all over the chart, nothing even close to what it should be.
Besides that, the toque spec is mostly concerning the material your are screwing the bolt into. And yes, in the bikeshops where I worked I've seen to many bolts worn-out which took us time to get them out.
On most DU's the crankshould be tightend at 35Nm, in a JIS BB the crancks go on 40 Nm, only Sram crancks go on with 50Nm, Cassette and centerlock lockrings also 40Nm, postmount bolts in general at 7Nm (between 6,8 and 7,4 Nm for most brands) so not that many values to remember.
And indeed, I am in the bike bussiness for almost 30 years now.(Trained in a differrent branche where would tighten bolts at 400Nm+... So bike tech is easy)
Hanging bikes under a carport is obviusly a perfect solution.
Bosch BNI cranckbolts go between 40 and 60 Nm, just came upin my brain.
Dorkyman,​
I fully agree with you on solvent stripping away the lubrication from the bearing surfaces of a chain. The solvent has little if any lubricating quality to it so to get new oil/lube into those bearings the new lube would have to strip away the solvent before it can get in and lubricate the bearing surfaces. Would you strip all the oil from an engine bearings to clean it each time you oil change? Think how long it would be before the new oil reached the oil striped bearings. I know there is the thought that one should wash the grit and grindings from the deep internal bearing surfaces of the chain. But how to effectively do that I believe is difficult if not impossible. Maybe an ultrasound cleaning will do it but then you still have to displace the cleaner from the bearing surfaces buried deep inside the chain before oil/new lube can get there. Some have recommended using compressed air to clean a chain but I believe that only drives the crud deeper into bearing/sliding parts. Yes it looks beautiful clean when you do that especially when it has some solvent on it before blowing it dry.
Ten years ago I had a Nissan whose lug bolts required 60 ft pounds. When it came back from a shop, I needed approximately 250 foot pounds to unscrew them. The mechanic was concerned with speed. He wanted to be sure they didn't come loose. As long as he didn't strip the bolts or snap them off, it was fine with him. Bicycle mechanics could be in the same boat.
The principle of torquing lug bolts is to take up elasticity so that the elasticity will keep it tight, but not to go beyond the point where the elasticity stiffens sharply because now you could permanently deform the threads, causing them to loosen more easily. I'd never used a torque wrench on those bolts. This time, I tightened them by feel, put on a torque wrench, noted where the handle was on the tire sidewall, backed off a quarter turn, and tightened until it read 60. The handle was in the same position as before I'd backed off.
I tried it on a Cadillac from the 1950s. It used lug nuts instead of lug bolts. They were SAE instead of ISO but required the same size socket. This time, the required torque was something like 100 foot pounds, which shows you can't estimate torque by the size of the fastener. Again, I torqued by feel, then used a torque wrench to back off and bring it to the specified torque. Again, the position of the handle showed that I'd been accurate.
The polyethylene chain guard on an Abound is screwed to brackets of sheet steel. As you say, the material you're screwing into matters, and I find Aventon's specs way too high. An ISO 2936 3mm hex socket key makes it easy.
You posted torque specs for crank bolts that aren't M8 x 1. The spec for this bolt is 17nm. I put a plastic handle on an ISO 2936 8mm hex socket key so I could torque by feel and see how many Newtons it put on the pedal. Then I took the handle off to see how many Newtons the key would let me apply to the pedal. It was almost the same as when I torqued by feel. Then I did the math. Both were slightly over 17 Nm, the spec for that kind of bolt.
is
On the Abound it is important to remove the O-rings from the calipers, or they will never be right. Torque everything down every 400 miles. Degrease a new chain, rinse, dry, and dip in hot paraffin, and it will never need attention again.
To check a bolt on torque applied when fastening you would use a wrench like this:
Those are designed for that type of work, a "normal" torque wrench is used to fasten a bolt at a given torque. A release force to break a bolt free is in fact something different.
Sorry to say its my daily job to check built bikes on bolt torque spec. amongst other things.
I use one of these 50 times a day. The big ones are mostly for cranks and some axle nuts.
@Base, What do you do and where about? I am in Nor. Cal and work on eBikes.
Morning,
Good question, at this moment in time I am a Q-engineer at one of the big bike manufacturers in the EU, I've been working at/with the big three American brands for years and been working in bike shops since the start of e-bikes in the BLX. My current role is mostly on E-bikes and Cargobikes.
These small click-keys are ok, not very accurate but it give's a good idea what you are doing. Just get them checked every now and then, I do own a row of torque wrenches and get these tested in our toolshop.
I suppose we should all get our torque wrenches calibrated -- and yearly at that.
Like when is that ever going to happen?
For private use that would be a hassle indeed, although you could build yourself a test rig
Beam style versions do not need calibration
just have been through some documents, these small t shaped fixed torque wrenches typically have an accuracy of +/- 10%, ratchet style wrenches are usually +/- 3% for a quality tool
I like a beam wrench because it's reliable. However, it's not precise; that is, reading the pointer is not exact. A clicking wrench is precise but could be inaccurate (unreliable).
Last year I bought a set of 7 calibration weights which I could use for 1g, 188g, and 124 points between. I tested a cheap digital kitchen scale after 8 years of daily service. It was consistently accurate to the gram! It uses strain gauge technology, which is a bit like a beam wrench.
I was so impressed that I bought this because it seems to use a strain gauge:
It's advertised at 2% cw and 3% ccw, but the calibration certificate showed mine to be far more accurate. I think it will stay calibrated like my scale. It showed me that my cam-type torque tool varies wildly from one click to the next. I think that's because friction on the cam is inconsistent.
Over time, I've been so pleased with the digital torque driver that I've ordered this one, which also seems to use a strain gauge. The driver was good to 6 Nm. The wrench is good to 60.
However, compared to a set of ISO hex keys, I consider these digital tools toys. To use a digital tool, you have to have it with you. To use it well, you have to know the torque spec, and the spec has to be correct.
I prefer Allen keys. In 1909, Allen discovered that the socket in a screw could be sized for a key that would apply the desired torque. Using an Allen key is like walking barefoot up a driveway whose gravel is increasingly coarse and sharp. You want to go as far as you can and still be able to stand there for 5 minutes. Even blindfolded, if you walk slowly you'll stop at the same place every time.
Before I came to rely on proper hex keys, I would tighten by feeling the torque take up the elasticity. That didn't work on the front axle of my Abound because I didn't feel any elasticity. The head said "8-10 Nm." That was from the toolmaker who designed the part. Aventon said 10-15 Nm. You can't always count on what an e-bike manufacturer specifies.
The axle has a 6mm socket. I put a package scale under the center stand so I could calculate how much torque I was applying with an ISO H6 key. The first time, I could not comfortably maintain the pressure. That told me I'd been too aggressive, as could happen to a professional mechanic in a hurry. I wrote down the Newtons on the scale and tried again, this time taking a few seconds to feel my way as I increased pressure. That came out to 8.9 Nm, almost exactly in the center of what the toolmaker specified. The first try, which had felt too high, came out to 12 Nm, which wasn't as bad as relying on Aventon's recommendation.
Aventon recommends 2 to 4 Nm for three washerless screws that hold the chain guard. That's ridiculous. The chain guard is polyethylene, and two of the screws thread into soft sheet steel. The sockets are 3mm. I used my digital torque driver to test my H3 ISO key: 1.0 Nm. That's plenty to secure the chain guard. It and the sheet steel threads will last a lot longer than if I followed Aventon recommendations.
Louis Armstong said, "You can't go wrong with a good song and a sincere heart." I think I know what he really meant. You can't go wrong with an ISO hex key if you take a few seconds to feel your way. :D
Same sized bolts with the same specifications come in different head forms so for different allen or torx keys. Besides that, the test setup at the eurobike shows that this methodology does not result in a correct torque apllied to these fastners.
Well lets concluded that you want to use your way which is fine, as a Quality Engineer at a bike factory I do have an opinion, and what you want to do with the advice is up to you. Great to live in a free world.
Besides that note, al bikes which comply to the EN15194 do come with torque specs which ensure that the parts on the bike are within these specifications and compliance validation.
Hi everyone,
3. Brakes
5. General Checks
Park Tool, the widely respected bicycle tool maker, has many useful how-to videos on YouTube — everything from routine maintenance to advanced repairs. That'd be a great place to start, as the tools needed are always specified, and every procedure is clearly explained and illustrated.
As you've seen, everything can be questioned. But you won't go too far wrong by starting with the Park Tool way. Their tools are generally good values for the money, but you can get by for less for routine home maintenance purposes.
You said when mechanics tightened by feel, the results weren't good. How did they check? Unfastening a bolt wouldn't tell because you'd have to overcome static friction. Nobody had mentioned ISO hex keys, but now you seem to be saying they were testing hex keys.
If I were a Quality Engineer at a bike factory, I'd use a torque wrench, too. However, when @gromike said keeping one calibrated would be a problem, you said, "For private use, that would be a hassle indeed." Has your opinion changed? Should he also carry a calibrated torque wrench in the field?
EN15194 is for bikes not over 250 watts and whose motor won't run unless you are pedaling and under 15 mph. My Aventon didn't come with a list, but the manufacturer went one better. Where proper torque is critical, it's painted on or beside the fastener. Every screw has a hex socket head. I checked my H4, H5, and H6 ISO keys, and all torqued very close to the specs. The screws with H8 sockets did not have painted specs, but the torque for screws of that grade, diameter, and pitch could be found online. The H8 key got them right, too.
I believe torque wrenches appeared in the 1940s, and the early ones weren't very good. Before that, industrial equipment depended on Allen keys for proper torque. They still work.
Like I said, if you want to work in your way and do not damage your bike thats fine. Btw, the first patent on a torque wrench is from 1931.
To get your torque wrench checked as a consumer, that is indeed a hassle, either buiild yourself a test setup or send it in to the manufacturor, PT does it for I thin 20 USD, other too or find a shop where they have a torque tester. Many carshops would have one. In our toolshop we have them, in the service workshop also. No big drama. Just a hassle. PT says 5000 clicks so thats some bike to be overhauled a few times.
And like I mentioned, there where max-torque sensors underneath the test bench, they could also use one of the other max torque tools shown above on these bolt heads. And also DIN and ISO bolts can come in an array of boltheads and thus sizes. In those case the logic doesn't ad up based on your "standard length wrench" method.
And for in field use there are plenty lightweight tools to use with either a preset torque, click style, or the tools which work like a beam style wrench, Lezyne or Topeak have a few spring tension torque wrenches which are ok for use when riding.
Btw, those "painted" marks are usually laser engravings, we see thos alot on parts. Infect with the upcoming EN1760 thats a requirement.
In production we use measuring tools to check if the mandatory torque has been applied, we measure those and the inspection station, in the production line they use torque wrenches.
And any Bike witch exceeds the EN15194 is basically a moped, L1e or L1be. So helmets, licence plates, insurance and drivers licence.
For the majority of Bike Riders doing there own Maintenance a Torque Wrench may be a good Idea if they use it.
If at all possible keep your Bike or eBike inside your home when not in use so it can dry out, not to mention wont get stolen. If your Bike is muddy, lay it on its side (the side where the Cable comes out of the Hub Motor) and handwash it with lukewarm Water with a bit of regular Dishwashing Detergent (please no Dishwasher Detergent) and an old Dishwashing Brush and rinse it off with clean warm Water. Every 1000 Km. (600 miles) take the Chain off if you can, soak it in Gasoline, brush it off with old Toothbrush and after Drying off with Towel immerse it into a Container with Motor Oil for 30 minutes before reinstalling. If you ride in a salty Environment cut the Maintenace Cyle in half.
