Ever try to use your stove with the burner only set to 100% the entire time?
I never use the presets... Same goes for my air fryer toaster oven.
Yes basically that's how it works... But by adding time and adjusting duty cycle legnth the end results in a microwave are drasticly different.
You do realize that a gas stove is a totally different thing and I use them in two totally different ways.
I checked a 1600 W hair dryer. At 117 V it pulled 11 A and used 1300 W. If it could be fed a full 125 VAC, it would pull about 12 A.
You people in the North America should "thank" Edison for convincing the nation 230 V was unsafe...
Don't forget the transistor!At that time it was very much indeed.
The only reason you use 230v is Europe is you're too poor to afford copper required to do it safely.
And you should thank the USA that we allow you to use our inventions... Electricity, GPS, Internet... etc, etc, etc...
Yes. And America is Great Again.The only reason you use 230v is Europe is you're too poor to afford copper required to do it safely.
I think the word is not "sustained" but "planned." Watts depend on voltage and power factor as well as amps. Breakers and fuses care only about amps. The NEC is about planning. It says a home circuit shouldn't be intended for more than 80% of the breaker or fuse rating. That gives the homeowner leeway to plug in something more powerful than the builder anticipated, or to have more devices pulling current than anticipated.Maybe a 1600W dryer would work if it’s really only pulling 1300W, spoke.
My electrician friend told me that a 15A breaker is really only adequate for about 1400W sustained — even if the math says they should operate to 1800W at 120VAC. In any case, all the dryers on the shelves in Wal-Mart were advertising 1875W and they were blowing the 15A breaker within less than 5 minutes of operation at high power.
Bottom line, I got a Conair 1200W model (which I had to order online) and that is no longer tripping the 15A breaker.
Spoke, FYI I was referring to a 15A circuit breaker(s) in a home that was built in the 1960s in New England. Not fuses. While I could measure the power draw, the problem is/was obvious when I did the math. In any case, the 1200W Conair dryer seems to be working fine without tripping the15A circuit breaker. It just annoys me no end that all the dryers on the shelf are 1875W, which seems ridiculous (to me).I think the word is not "sustained" but "planned." Watts depend on voltage and power factor as well as amps. Breakers and fuses care only about amps. The NEC is about planning. It says a home circuit shouldn't be intended for more than 80% of the breaker or fuse rating. That gives the homeowner leeway to plug in something more powerful than the builder anticipated, or to have more devices pulling current than anticipated.
Fuses were another reason to plan to use only 12 amps (80%) in a 15 amp circuit. Did you ever have to replace a fuse in a car or house and find no possibility that there had been an overload? At 15 amps, the resistive element of a 15 amp fuse will get almost hot enough to melt. Cycles of heating and cooling can cause fatigue. Eventually, the element will break, with or without evidence of blowing. Limiting usual current use to 12 amps would reduce heating by a third, which would reduce fatigue.
Instead of guessing that a hair dryer uses more than 12 amps, why not get a meter and measure? I already had three when I bought this one. It was so cool that I bought another.
Homes I've seen with fuses have had fewer 120 V circuits than those with breaker panels. Fewer circuits mean a greater risk that when you turn on a hair dryer, there will be other stuff pulling amps through the same fuse. That may have been the problem at your mother's house. A 1200 W dryer looks like a good solution.
When you opened this topic I understood you to say the bedroom was on a fuse. That's what fooled me.Spoke, FYI I was referring to a 15A circuit breaker(s) in a home that was built in the 1960s in New England. Not fuses. While I could measure the power draw, the problem is/was obvious when I did the math. In any case, the 1200W Conair dryer seems to be working fine without tripping the15A circuit breaker. It just annoys me no end that all the dryers on the shelf are 1875W, which seems ridiculous (to me).
Hi spoke,When you opened this topic I understood you to say the bedroom was on a fuse. That's what fooled me.
Did your 1800 watt dryer have a plug like this? I'm sure it's against the National Electrical Code for a manufacturer to use a plug like this on a device that draws more than 15 amps. Even if on 20-amp circuits, household receptacles are rated at 15 amps.
If your dryer was tripping a 15 amp breaker, the simplest explanation I see is that there was something else drawing amps. When homeowners started buying electric fryers, coffeemakers, microwaves, and dishwashers, a lot of kitchens had that problem.
I disagree with the current d_bag in charge..
suspect she has many miles on Her by now.
one of my neighbors used nail polish on a tick on her poodle,it apparently wasn't working fast enough,she tried to light the tick off,didn't work so well.
terrible invention. Toaster: likewise.
My $17 toaster is pretty cool.
It uses a solenoid to hold the toast down and the power shuts off even if the toast gets jammed, so it doesn't start onand you can go ahead and stick a fork, knife or your finger all up in there to pull the toast out without getting Zapped.
The toast can be hot, but toast is always hot.![]()
