Bafang Bluetooth app
m00ms
United Kingdom
Hi all,
I am new to this forum and new to E bikes.
I have just built a trek Marlin using a bafang 750w kit with a Sw102 display.
Am i right in saying this display is bluetooth ?
When powered up i can find it on bluetooth but i get a message saying i need an app to connect.
Any ideas what app i need to use the bluetooth function if possible ?
Thanks
Thanks for that, sadly it didn't work as it didn't seam to open fully , I also tried the + app.
This is what screen I got when opened
From what I understand it's not ready for prime time.
I would put it on hold and see if 2025 brings any improvement
I thought the bafang kits and this display had been out for a while now.
They have been but the Bluetooth feature never caught on and has been a terd from day one.
There's a rider on here who has the latest model of their top of the line mid drive/display and he's never been able to make any use of it. So I'd forget about it working with a BBS* add on kit model for now.
Would I be right to say that to be able to do Bluetooth programming then I would need eggriders sw102 display ?
That's one way... Yes. But personally I hate the tiny buttons and display on the eggrider. Plus sometimes it can be buggy. But honestly I haven't touched mine in years.
I find the SPEEED App and a cable easier though perhaps a bit more cumbersome to repeatedly set up. I purchased a display cable "Y" so I can connect the program cable without the need to unplug my display.
Just confirm your setup is using the UART communication protocol, not CANbus.
Round display cable not pentagon shaped.
Likewise the display is a bit small and fiddly but I do like it’s size as I’ve managed to tuck in a gap on shimano m7100 slx brake lever which gives it quite clean look on the handle bars.the bafang sw102 display does seam a bit useless with its Bluetooth.
That’s good I’m on the right track , I have ordered a programming cable and have the speeed app ready.
My plug is the round green one.
I prefer a giant mid mount display with separate buttons easily manipulated blindly mounted near the grip... But hey, there is no wrong when it comes to personal preference.
Just make sure you have a USB to what ever port you have on your phone adapter as well to work with the programing cable. Typically type C these days.
I sort of like larger screens but then I also like the smaller screen being tucked out of the way.
I’m going to use Samsung tablet with speeed and I have same connector to turn type C into USB
Never programmed an e bike before. Currently it feels full on with poor low speed control in even mode 1 which makes riding through towns tricky as the bike wants to just go the moment you do a slight pedal turn.
I'm using something similar to this... Much more refined.
Smooth Ride Post #123
If you're bored you can start from the beginning of that thread for some background.
There's also a few other threads about with some other strategies for taming the beast.
Thanks for that which will be very helpful, it will be over Christmas break that I will play with programming it so I can go for quick rides in-between setting changes.
Thanks for your response to my post which is very appreciated 👍
Coolio...
Let us know if something isn't as you like and we might be able to tell you which setting to adjust.
Settings can be personalized to bike, user and terrain.
Bike is now programmed up which has made lots of difference but i now have another problem, Not sure if its the final set up but for the the minute its loads better.
I was a happy bunny until i noticed that i have excessive play in the bearing on the motor directly under the chain ring.
Time to get the kettle on and read up on changing it and if theres other bearings to change while its in bits to prevent further failures!
sw102 is not an eggrider. And none of these alternatives can be classed as "Much more refined.", you're pluggin cables in ffs, i pull my phone out to program, thats it, on the trail or at home no different.
No one suggested that the sw102 is the eggrider... though the eggrider is built off of the sw102 display and looks similar.
And the "much more refined" was referring to the settings, not the method of programming.
Reading comprehension much?
Never had an issue with the bearings so I never researched replacement.
Let us know what you find.
