spokewrench
- USA
After I bought an e-bike in 2020, I found that the cleats on the resin pedals often cut my shin right through my pants. Sooner or later my shin was bound to collide with the pedal as I walked beside the bike to push, pull, or turn it, usually in the garage. I didn't know why cleats were necessary. I'd never been injured in the days of block pedals.
The cleats on another bike with resin pedals also cut me sometimes, as did the cleats on metal pedals. I hated cleats for another reason. You won't get your foot perfectly positioned when you first put it on a pedal. I like to make corrections, to get the ball of my foot over the spindle and, to minimize leverage that might snap a spindle, get it as close as possible to the crank. It was easy to take the pressure off a block pedal and slide my foot a little, but with cleats I had to lift my foot and try my luck again.
Unlike the resin pedals, the metal ones began to click after a thousand miles. I wanted to replace them anyway. I'd noticed that my feet tilted outboard because the pedals didn't extend far enough from the cranks to support the width of my shoes. I chose the red metal ones because they gave me wider support, had 3 rows of ball bearings, had reflectors, and had removable pins. Slipping had never been a problem with block pedals. I could unscrew the pins on my new pedals to test for slippage. If it wasn't a problem, I'd have safer pedals that would make it easier to reposition my feet.
The material of soles affects traction. With two different kinds of shoe, slippage was no problem even when I walked across wet grass to mount. With that bike, I don't have to worry about my shin, and I can position my feet better.
I was so pleased that I bought the yellow ones, more expensive ones of the same brand, to replace the resin pedals on my other bike although the original pedals were fine. I discovered too late that they have no reflectors and that unscrewing the pins would cause the pedals to fall apart. I do not agree with the manufacturer's idea of higher quality. I took the trouble to grind down the outboard pins to see if there was an improvement. There was. Now I'll grind down the rest.
