Court and I tend to agree on the somewhat hidden merits of the Izip Peak electric mid drive mountain bike.  Consider the following:
Like many of us, I really like the looks and specs of some of the new mid-drives coming out of Europe, but the Peak is available (backed with an apparently responsive company) and is so reasonably priced, that it may prove a great alternative to consider. It is also a hot rod, kinda like a Corvette, vs the Haibike which is more like a Porsche, which is more exclusive and refined apparently, but not as fast!
P.S. Included a foto of me educating a bunch of co-workers on ebikes, with my Peak being the demonstration vehicle. If you haven't figured out by now, Yes, I really like it!! .
Cheers,
Rusty
			- The Peak is the only mountain bike that is classed as a high-speed pedelec in EBR's tests.
- It is rated (and warrantied) by Currie as a condition 3 hardtail - rated for true off-road usage "for cross country, marathon riding and racing over roots, rocks, etc." (from the owner's manual)!!
- The transx mid drive unit powering the Peak has not suffered from reliability problems. (no bad batches like the some of the Currie hub drives)
- The mid drive in the Peak is rated at 73nm of torque. Bosch standard drive is rated at 50. Even the Bosch performance line is rated at 60nm. Is the Peak the most powerful mid- drive production bike you can buy right now? And the cheapest?
- Even if you can de-restrict the Bosch's speed cut-off, you still won't give the Bosch motor any more torque than what it is rated at - it remains at 60 nm which is still about 20% less max torque than the Peak. And de-restriction may cause warranty and other problems. Not so with the Peak!
- The Peak is beefy, with a massive tapered head tube and top and down tubing. Compare the build and front fork to the Neo line of mountain type bikes like the Neo 650B Jumper from Easy Motion for example - you will see the difference.
- The Peak has a 48 volt system, like the Dash. Almost everyone else, (including Bosch) are still using 36 volt systems.
- If you just slightly pause before you shift, it does shift smoothly.  SRAM units in general kind of "clunk" anyway under load on all bikes .  The Bosch units actually reduce the motor's torque under when shifting, but you can just do it yourself on the Peak ( like a clutch vs an automatic).  No big deal once you get the hang of it.
- The Peak has a throttle (though limited to 6 mph by design). It enables and assists restarts and rough going in single track conditions. It is a great aid when starting off and when plonking around trails.
- The Peak is not overly heavy (around 49 lbs) and is actually easy and fun to drive without any electric assist. It offers a 27.5 wheel diameter as standard fitment.
Cheers,
Rusty
