To expound on this a bit further, wheel diagnosis is actually pretty complicated. We would like to think our wheels are built like DT Swiss:Spokes can loosen with usage.
That can be made worse if they have not been torqued properly, and or were installed without spokeprep
Yeah, I know the DT Swiss video is long, but near the end they show how the wheels they build are put through a side stress machine as one of the steps. Hand built wheels are the best.After building many wheels over the years that never had spokes break/loosen I would blame it on a poor wheel build to begin with. In fact I don't use a tension gauge although I tried one years ago. There are steps you make while building such as pre-stressing the wheels a few times side to side and having a feel for tension based on experience. Most wheels are machine built and put in the box and if upon receiving them one would go through them they would have less issues. Quality components also make a difference.
Trek certainly shouldn't be buying or shipping garbage. My yubabike has ~12000 miles with no spoke problems on the yuba wheel. The gross weight is up to 330 lb with groceries & ag supplies as cargo.My bike is a Trek Verve +3 with 3600 miles on it. The loose spokes has just started happening, 2 have gotten loose. The bike is rated for 300 pounds including the bike and me and the bike are probably 295. I also ride on paved roads mostly but they are pretty rough.
You're due for a visit to somebody that's familiar with wheel building. Done properly, that should end your spoke issues IMHO. Don't let some rookie replace or adjust one loose or broken spoke. One of those is indicative of a larger issue.....My bike is a Trek Verve +3 with 3600 miles on it. The loose spokes has just started happening, 2 have gotten loose. The bike is rated for 300 pounds including the bike and me and the bike are probably 295. I also ride on paved roads mostly but they are pretty rough.
28 or 32 spokes?My bike is a Trek Verve +3 with 3600 miles on it. The loose spokes has just started happening, 2 have gotten loose. The bike is rated for 300 pounds including the bike and me and the bike are probably 295. I also ride on paved roads mostly but they are pretty rough.
This.So if you within the specified rider weight limit , and it's under 2 years old, go visit your trek dealer before touching the spokes
With ebike should be tensioning rear wheel every 6 months, especially on cheaper models. Once spokes start breaking really up for rebuild which should result in stronger wheel. I've broken few spokes on my Trek 29 ebike none on higher mileage 27.5" Cube and Moustaches (10,000km). Suspect it is cheaper build quality not larger diameter which is reason Trek breaks spokes.Trek certainly shouldn't be buying or shipping garbage. My yubabike has ~12000 miles with no spoke problems on the yuba wheel. The gross weight is up to 330 lb with groceries & ag supplies as cargo.
