Agree, Bleeding the brakes etc is a routine job. My concern as I've mentioned prior. This a 'new' bike. New brake system shouldn't have a catastrophic failure...period.Good point about it being a new bike. Take it back to the dealer. It should be under warranty. Long-term, bleeding brakes is a routine job. Depending on your comfort level with simple mechanics, it is the kind of job that many people would do themselves.
TT
If he's asked the question as he has... it's probably beyond his mechanics skill level at this point.It does sound as if a simple brake bleed and fluid top-up would be in order. But are these brakes using DOT fluid or mineral oil (a DIY job needs to know in advance)? The sudden loss of pressure across BOTH levers sounds like a dual failure of poor quality parts. Which is ordinarily highly unlikely since they are independent systems, but at this bicycle's price point, maybe not so much. Did the brakes fail or did they just both degrade severely at an equal level? It could be that, and I would not be the least bit surprised if some assembly line worker did a poor job of tightening the hose fittings to the calipers (plural) and the fluid leaked out. Did the leaky fluid instead come from a leaky piston inside the caliper? If so its extremely likely you can bleed all you want, and still have a problem due to contaminated pads that need replacing. No matter what the source of that leak has to be found and addressed.
This could definitely be a simple, routine bleed coupled to a torque check on the hose ends. Or it could be a lot worse. Depending on @fishwagon 's level of mechanical aptitude the first steps in correction could be very simple. But if he's not mechanically inclined, its definitely a shop job.
Thats what I was going for. A definite maybe to be sure.That said... None of this is rocket science and easily learned if you know what to do with tools.
I dunno... the low end heavy ebikes with the stretchy cables and need to re-adjust every couple of weeks are their own sort of dangerous problem. Thanks to the Rad Runner lawsuit I think we are going to see a raft of cheap ebikes with cheap hydros coming from the factory ... which means this is probably a whole new class of common failure coming down the bike path to forums like this.I realize Hydraulic brakes make a great selling point but these low end bikes should have cable pull for reliability and ease of repair.
You should have some skills to own one of these and at least the cable pull don't require any special tools and only a bit of common sense.Thats what I was going for. A definite maybe to be sure.
Exactly... It's better to have this $10 razor that works and you can easily buy blades forI think that you are both right. It is so easy to replace the $1.25 cables on a Big Box bike with $8 or $12 ones. The cheap ones stretch, corrode with white powder and are rough. I just delivered a bike and walked a couple of miles of trail back and was thinking about this thread. Here is what I came up with:
Did you ever invest in cheap-ass razors? How did that work out? Like a cheap-ass bike it is a waste of good money.
The thing IMO is STOPPING is one of those things that is necessary. 1) Avid mechanical MTB are $100 for the pair of calipers, $12 for the lever set and decent housings and cables another $40. A $152 investment to be able to reliably stop. The alternatives are 2) to not use the bike at all, or 3) death.I don’t think so as it hasn't happened yet
I've asked the poster several times how the brakes failed... Slowly, getting worse and worse or catastrophley with no warning, but haven't seen a reply.The thing IMO is STOPPING is one of those things that is necessary. 1) Avid mechanical MTB are $100 for the pair of calipers, $12 for the lever set and decent housings and cables another $40. A $152 investment to be able to reliably stop. The alternatives are 2) to not use the bike at all, or 3) death.
He may be dead already.I've asked the poster several times how the brakes failed... Slowly, getting worse and worse or catastrophley with no warning, but haven't seen a reply.
If the brakes failed with no warning I would never ever ride the bike again. Even if they failed slowly over a short ride... Remember the bike is 'brand new" .
We're talking about the poster / rider potentially being killed. This is not a science project nor amateur night..."Try this and see if it works." Say it with me "Death "
Oh yes, The no name, no battery management system charger. Not in my home or garage !
I really hope 'fishwagon' is ok ?? If you're out there please check in..He may be dead already.
I might have been too harsh. I apologize.fishwagon' is ok
The OP said, in post #10:I've asked the poster several times how the brakes failed... Slowly, getting worse and worse or catastrophley with no warning, but haven't seen a reply.
I got the bike new about 4 months ago. I just put 300 miles on it. Yesterday the brakes were fine, today they weren't. I was going down the steepest hill in town, which is steep, I pumped on them and there was nothing.
