What color is best for deterrence in bike locks
There is a YouTube channel called lockpickinglawyer. He can pick about any lock in s minute or two. There are ones interested in your bike not too far behind.
*I have watched many of his videos. He has often said that competent lock pickers do not often go for bikes, but more lucrative opportunities like cars and homes. I do believe he was very impressed with the Hiplok D1000 and the Litelok X3 but they are $300.00 locks. Maybe next year ...
Pink and orange with a Fisher Price sticker on it. That will confuse them!!
Run your cable lock through THIS!!
And this!!
am now looking at the Hiplok DXC (the one with the Diamond certification)and will continue looking
The loop part of the hiplok DXC would probably take 5 minutes to cut with a battery angle grinder. The cable part appears to be no better than the master/amazon/ebay/bike-shop cables with extra flexible (tiny) wires that could be cut by a $20 7" diagonal cutter in about one minute. My SS mcmaster 1/2" sling would take 30 minutes to cut with 7" diagonal cutter. I tried cutting a SS cable the city left laying on the ground by a traffic light. Made of thick SS wires, cutting each wire individually took 6 minutes to cut one strand. There are 7 strands. I estimate a $50 harbor freight bolt cutter would be severly damaged by the mcmaster SS 1/2" sling. There is a $280 SS capable 1/2" cable cutter at mcmaster, but no thief is going to buy one of those since I'm the only person that ever used a SS 1/2" sling to secure a bicycle.
Frustrated thieves have knifed my tire twice as my bike was parked on the street. One stole my tool box, but none has ever knifed the spare tubes or tire in the pannier.
A solar powered electric fence controller may be a wise choice as a deterrent.
Stainless steel. PIT* to cut with grinder. Nobody has messed with my 1/2" cable, 4.3 years. Your litelock won't wrap a power pole or gas meter pipe, my 6' cable will. Weighs 7 lb, rolls up in a 21"x21" pannier. https://www.mcmaster.com/8942T15 Litelock shows locking to a sheet metal bike tether, that I could cut in 5 minutes with a $6 hacksaw. I won't use 1/2" steel post bike racks, either. No idiot saws down a live electrical pole. Nor a meter full of pressurized natural gas.
Lock, chrome plate. Abus 92/80 looks better than it really it. Pin is 12 mm steel, spins if you try to grind it. Body is 2.5 cm square, looks like steel but it is brass. Weighs over a half kilo. https://www.ebay.com/itm/383864725103?epid=1300986808&hash=item59601ede6f:g:5NEAAOSwY2Zf3Mpn:sc:ShippingMethodStandard!47130!US!-1&amdata=enc:AQAHAAAA4LmrcZTxDg6bSA77cHSdLxlAWP3Ow4ZVWK0yUbRM+QM5DbNMdQlWFlBPbv7nEXch5pyY6zj+b4CvepXQIejh6oO0+CZxglDWkLvhhFI37shgynkuixobfF0SHRvHRPXeWOaFJFzEGZ6zp+vnTpLaZ7jdB8UE2TMFgNP0J23w0W4LnWVCPNZJ6ZsyCGn4pfoYT+lStixCWNLiHzV5pKg8PgKR7xpBpqv2Sg7xvtZOYpgBRJMcKq8ei4aTMlPAo+nrsl73zH+eQnLI8+4QbjD+xLAdVkel3KWRWFP92FA3Bx3j|tkp:BFBMwqSYruZh
Abus 37RK80 looks as if the eye wouldn't clear two sling loop
This cable might be the sleeper product to get. Would the 3/8" work close enough as I need it to roll up smaller than yours does? On looking more closely, the 3/8" is steel while yours is stainless steel. Does that matter?
I’d like to see a pic of this, the how you made the loop for the lock.
I believe the SS is the more cut resistant, similar to being tougher to drill, lack or carbon or something. If this link shows up you can see the SS coated ultraflexible cable, I think this is ready made looped but you should check. I don't see 1/2" in the 7 x 19, but the 3/8" fits the bill. Even has your different colored coatings:)
Your link has the eyelets but no coating. I would want coating. My reference has coating but no eyelets. Otherwise same stuff. I would call them and tell them what you want. I have a long heavy square link chain but would prefer something like this cable.
And I’ll bet they use a ss ferrule or i would ask.
