Hi Everyone, I am attempting to upgrade both the lights (from stock to Lupine SL) and the display (from Purion to Nyon 2) on my Gazelle Ultimate C380+ Speed.
Problem(s): it seems the cables' hole on the headset tube is too small to pull the connectors through as is. There are two cables (display and the front light) and the rear brake line run through the hole now (see pics). Three in all. Has anyone done this and can please clue me in? So far what comes to mind is to remove the brake line (to make room), then pull out the light plug (smaller), and lastly the display plug (larger). After that try feeding cables/plugs back as follows: the display plug first, then the light plug, and lastly the brake line. How did you do it? Thank you!
PS: on the pic inside the downtube, left to right: (1) brake line, (2) display cable with connector wrapped in black el. tape, and (3) light cable.
