Rexlion
- USA
- City
- Tulsa metro
I've been curious about energy usage in different PAS levels. Today I rode a particular gradual (but steady) incline twice, trying to maintain as close to exactly 10 mph as possible each time. The first run was in PAS 1 (set at 40% power), and the second run was in PAS 2 (set at 66% power). In PAS 1 the motor was consuming about 110 watts. It was harder to keep my speed as steady in PAS 2, so the wattage varied more, but it seemed to still center around 110 or perhaps 120 watts. In other words, achieving the same 10 mph speed with more motor assistance didn't appear to use a significantly greater amount of juice. This was with a hub motor and torque sensor.
Has anyone else tried similar experimentation?
I'm hypothesizing that the greatest battery range penalty from higher pedal assist settings might come from the rider maintaining a higher speed (because pedaling becomes easier); but if one sticks to the same (lower) speed, the higher PAS might not hurt one's range all that much. What do the rest of you think?
