I have the aluminum Creo. It might be there but you have to feel for it. Good luck. Otherwise, I think there are collars that can fit on the seat post that provide attachment points.Is this creo?
Mine does not have this one here.
With a carbon frame I'd personally want to go with the seat post mount, instead of using the fender mount. Heck, if the seat post can support the entire weight of the bike on a bike stand I doubt the attachment for the rack will over-tax it.
That’s the rack that I have in mind for a possible 1200 km trip out to the west coast next year. Does it require a standard 6mm hex to remove the Tailfin axle on the quick release version? I was considering the QR frame mount but am now thinking that the thru axle would be a much more robust attachment point with loaded panniers.I have the Tailfin they are very well built and constructed. The weight of the rack sits on the through axle with the seat post attachment to keep it steady.
Yes it's a 5mm. I think they have added to their axle offerings but at the time they recommended the universal which is two pieces. It is easier to install on the non-drive and remove on the drive side. I went with the Carbon Aeropack with pannier mounts and fast release dropouts. I also have a set of frame mounted adapters on a second bike. It is cheaper to get the small accessories with your main order due to shipping. I went with a set of the mini panniers assuming I could use their pannier adaptors if I need a larger bag. The Aeropack is nice because it's easy attach it just before a ride if you need to carry more clothes or a RE battery. Everything is extremely well made with excellent fit and finish and they do not cut any corners to make sure it all does what it is supposed to do.Just found the answer to my question. From their website, it appears to be a 5mm hex that’s required as is on the stock axle.
Thanks for the helpful advice. I’m undecided between the 10L and 22 L panniers but the 20L trunk bag is a definite must as this trip will likely extend out 12-14 days. My wife and I would really like to travel as light as possible since our objective would to be overnight after each leg at roadside inns/motels. We’re not that young anymore to take bikepacking full on.Yes it's a 5mm. I think they have added to their axle offerings but at the time they recommended the universal which is two pieces. It is easier to install on the non-drive and remove on the drive side. I went with the Carbon Aeropack with pannier mounts and fast release dropouts. I also have a set of frame mounted adapters on a second bike. It is cheaper to get the small accessories with your main order due to shipping. I went with a set of the mini panniers assuming I could use their pannier adaptors if I need a larger bag. The Aeropack is nice because it's easy attach it just before a ride if you need to carry more clothes or a RE battery. Everything is extremely well made with excellent fit and finish and they do not cut any corners to make sure it all does what it is supposed to do.
You will probably have to leave the lawn chair home.I sense that we might require a pair in each size to compensate for any extra clothing/gear/food we may need to take for the length of time that we're out on the road. If so, it may be a case where I end up with the larger panniers on my bike and my wife with the 10L versions. Will definitely have to nail down a list of essentials/non-essentials that we intend to bring along before we commit.
I appreciate the reality check. You can tell that I’m a relative newbie when it comes to planning how to pack for an extended trip. We’ll have to keep it simple and not get too carried away since we won’t be too far from civilization so the list won’t include lawn chairs.You will probably have to leave the lawn chair home.
That same thinking always presented itself when going on long backpack trips. But it even occurs when planning for nordic skiing in Europe - what to take, what to leave. Essential as opposed to "nice to have." It even happened with my recent trip to Iceland. Dealing with a heavy, over-packed suitcase caused a lot of packing, unpacking and repacking. Just one day walking on a glacier required gaiters, traction devices, warm clothes (mittens, puffy jackets, hats, warm pants, etc).
We actually have a Helinox and used it extensively on our seakayaking trips. It would be nice to bring it along but I’m not sure that we would use it much for this specific trip as it still is quite rather bulky for a collapsible chair though I presume that one could separate the components. Our particular chair has a packed weight of 2 lbs. I mean if people take these backpacking…why not?Don't rule out chairs, the Helinox Chair Zero is only 17 oz (510 g) and supports up to 265lb. If you will be doing such a long trip with planned accommodations based on no sleeping or cooking gear, you should be able to send stuff ahead or mail stuff home just like the PCT through hikers do. Weather is always the big unknown.
