Catalyzt
- USA
Hi, folks,
Yesterday, I had my first ride over 10 miles for the season (15 miles, 1,100 feet of vertical) and I noticed that the chain was often not dropping into the right gear when I moved the shift lever a click-stop, made that rattling 'between gears' sound or didn't shift.
I also noticed that a few times when I was supposed to be in high gear, the crank was freewheeling-- no resistance while pedaling, no power being delivered to the rear wheel. What does this mean? Had the chain jumped past high gear? Or maybe didn't make it into high gear? I'll put it up on a cinderblock to check, but I'm guessing it jumped past 10th or was stuck between gears somehow. Never had this symptom on an acoustic bike.
Sometimes, it would pop out of gear and kinda freewheel, but with that rattling 'between gears' sound-- that's a symptom I am familiar with, the kind of problem I expect after owning any bike (or replacing the derailleur) after 18 to 24 months.
I'm going to prop the crank/motor on a cinderblock, leaving the front wheel in the rack, and try some adjustments, see if I can avoid a trip to the shop. I found a video tutorial for an acoustic Shimano Deore that seems pretty similar.
Any tips, links to relevant videos, warnings, etc. would be welcome. I just don't particularly want to lose the bike for four or five days, which is the typical turnaround for this time of year, or spend the money to adjust the cable tension if that's all it is.
What makes me a little suspicious -- the onset of the problem seemed very fast. Like, maybe it slipped a gear once or twice on the last ride or two, but it got much more pronounced during yesterday's ride.
Thanks so much!
Deiralleur:
SHIMANO RD-M4120, DEORE, SGS 10/11-SP, TOP NORMAL, SHADOW DESIGN
Cluster:
SHIMANO CS-M4100-10, DEORE, 10-SPEED, 11-13-15-18-21-24-28-32-37-42T
Thanks so much!
Deiralleur:
Cluster:
