fdny37
- USA
Ok, so I bought a 20ah ebike battery off Amazon which I put in my Topeak MTX bag. The Topeak bag is attached to the rear rack with the Topeak Omni QuickTrack Adapter. The battery fits in the bag like it was made for it. I just cut a slit in the corner of the bag for the wires to pass through. With this setup you can just unplug the battery and slide off the bag and take it with you if you have to leave the bike. I got the dual battery parallel connector from Bolton Ebikes and the thing works just like they say. I had to get some XT-90 pig tail connectors also from Amazon. You will have to open the the bike up and cut the wires to the controller which are the wires to the battery. The wires from the controller go to the male xt-90 on the battery connector and the batteries go to each of the female xt-90's. It is a pretty simple install because you are just connecting wires together. Now I haven't had a chance to take the bike for a long ride but I did go for a spin around the block and everything is working perfectly. It is a 20ah battery so now I should have 30ah and triple the range. I was only getting 17 miles so I was a little disappointed. Hopefully this will work as I think it should. Now if you don't now how to work with wires don't try this.
