pawtoki
I thought I'd show how my Tilt-a-Ramp bike carrier works and looks.
It's not pretty! It is very solid. Holds up to 400lbs and is easy to use. I have approximately $600 invested in the entire setup. It can handle very heavy bikes with ease without having to remove parts. I've taken an 1800 mile trip to ride several Rails to Trails paths and was completely satisfied with the trip.
- I did modify it by adding two LED light strips for lights, brakes and turn signals.
- I drilled two holes in the ramp to allow water to escape from the left end.
- I drilled a hole in the ramp to run a braided cable from trailer hitch through the ramp bed and bike to the class III hitch to keep the honest people honest.
- Three anti-rattle clamps to tighten the frame connections of the car, and ramp assembly(s).
- Two wheels on the end of the ramp to make it easier to move when off of the car. At 70 years of age I'm not as strong as I was when I was of a whipper snaper age.
- Lift gate on Subaru does clear the bike. It helps to lean the bike away by loosening a web tie. closest to the car.
- My Swagman bike rake can be inserted in the end to carry my wife's semi-recumbent bike. I know it looks like a red-neck design with the second bike carrier, but it works.
- Added a combination safe/lock box to the lower receiver to leave my keys with the car.
