Ok, so one of the biggest issues I’m having with my new Hydra build is chain/tire rub when going into the taller gears. My current setup is 90mm wide Nextie Tri Spokes with 26X4.8 Maxxis Colossus tires. As it sits I can only get the first four cogs on the cassette before the chain rubs the tire. I next tried a set of Sunringle 80mm wide rims with Vee Tire Apache Fatty Slicks in 26 X 4.5 and the chain rubs the tire after about the first five cogs on the cassette. Now the Fatty Slicks run large so it’s not much different in width vs the Colossus tires. I thought going with a 80mm wide wheel vs 90mm wide would help but it’s not enough.
I am determined to use the Tri Spokes as I spent a lot of money on them and they look badass. So my next attempt will be a set of Surly Edna’s 26 X 4.3 on the Nextie’s. If that doesn’t work I’m going to try a set of 26 X 3.8 tires on the Nextie’s. Hopefully that works otherwise I’ll be super pissed.
Now before anyone says anything this has nothing to do with problems with the Hydra design or the bike itself. The bike appears to be designed around a 80mm wide rim and not for super wide massive fat bike tires. I tried to stuff the widest rim and tire combo I thought would fit and it doesn’t so I’ve got no one to blame but myself for the issue I’m having.
If any of you have a Hydra Fat Bike and are running 90mm wide rims and your not having chain/tire rub issues please post what tires you are running.
