Aftermarket rack and fenders for Turbo Vado SL
CLHall
Hey all. I just bought a Turbo Vado SL (in red) 4.0. I would have bought the EQ if I’d been able to get it, it comes with rack and fenders... but, silly me... I figured if it HAD the ability to come WITH them, certainly I could ADD the damn things. Not so fast, apparently. It does say it is “rack time” compatable” but there are no eyelets on the thing (there is a fender eyelet) and who knows how to make which one fit. I’m not rack savvy... I bought it to do touring and am now wishing I’d just bought the EQ. Honestly, I’d rather have a Tubus rack on there, I want something aesthetically pleasing, but whatever. Help!
Have you asked the dealer? They don't show the fender kit on the Specialized web site but the dealer access may show something. I don't particularly like Specialized fenders in wet weather (Turbo S) but they've integrated the rack and fender. You may be able to use P-clamps on the seat stays for a Tubus or Racktime but it won't have the sleek look. (I prefer Tubus too.) I tend to think their fenders are designed by someone who's never ridden much in the rain and they have too much form and not quite enough function. I've ordered the EQ version in spite of this.
Here is another example of how to connect a rack to a bike without eyelets:
or
I think the Salsa looks better but the Sunlite has a view of one installed so you can see the idea.
The fenders should not be much of a problem. It will be a little crowded on the rack/fender eyelet on the dropout with the fender stays and rack on the same attachment with a longer bolt.
I mounted the exact vado SL rack on my wife's SL without fenders, as she doesn't like fenders.
Mike's bikes sold the rack, though specialized stores can order it, but they say it won't work without the fenders, as they would refuse to do this simple customization.
I made a simple part that utilizes the SL mounting place under the seat inside the rear wheel stays (see pics and my other post)
Friends,
Please help. Find a popular aftermarket rack and make advice how to mount it on Vado SL non-EQ. (A question from a person who wants to buy the non-EQ).
Well that’s a wildcard question. I think @RobAtl has an elegant solution. If you don’t like that one only needs to search Amazon for two minutes:
etc etc. plus a conventional rack.
or go the easy route:
I would suggest getting the EQ version if it exists in inventory. E.G. I didn’t realize the EQ fenders were so nice until the bike arrived. In the beginning I imagined just removing them. But actually they are an excellent design!
If that existed in the inventory, my contact wouldn't need to ask me.
Unfortunately, the Specialized rack and mudguard set is not available, either.
It is not so easy to find a good standard rack. After some verification of the size etc., I recommended this
PLETSCHER Quick-Rack system pannier rack
It is a Swiss-made thing that I use on one of my e-bikes. It mounts to the rear triangle with M5 screws, and is supported at the seatpost in the front, with quick release. The rack is rock solid, with the rated load of 25 kg. The rack is available in several Polish online stores, making it easy for my contact to buy.
As long as Drytech mudguards are used in urban environment, they are perfect. However, a single trip to a forest makes you start cursing. Any little twig gets entangled between the wheel and the fender, making the wheel abruptly stop rotating. Pebbles nastily rattle inside, and mud accumulates rapidly there. All because of tight clearance between the fender and the wheel; and because of extremely long front wheel mudflap (which is otherwise beneficial in heavy rain).
If I could choose again, I would buy the non-EQ version and modded it, especially by using leaf-type "ass-saver" or "blade" detachable MTB mudguards.
I just received my Vado SL 4.0 and am absolutely thrilled, but the lack of seat stay mounts are my only complaint. What kind of commuter doesn't have rear rack mounts?!
Vado SL has never been a commuter e-bike. It is a fitness e-bike. Fitness e-bikes are to be ridden without fenders or rack.
Highly specialized ones - like the Vado SL. 🤣
Ye Goode Olde Specialized certainly know their specialties :)
I think the only reasonable thing to do is to order the fender and rack set from the Specialized dealer.
I made the same aluminum plate to mount the rear rack without the fender.
Here is my aluminum plate order information.
AL50XX series material, 300 mm long x 12.5 mm width x 2.5 mm thick
I just put a SKS X-Blade rear mudguard on mine. I think it suits the bike quite well.
Regarding a rack, I would have thought anyone needing to use one regularly has probably bought the wrong bike.
Re-visiting the old thread. The ultimate aftermarket fenders and rear rack for Vado SL un-EQ are:
  • SKS Speedrockers (fenders)
  • Ortlieb Quick Rack (rear rack)
Both items work extremely well on Vado SL, and can be uninstalled and reinstalled again in a few minutes.
For anyone wanting to add a rack to a non EQ SL, Specialized sells a combination seatpost/rack clamp.
Part # S184700001 (30.6 mm) $20 US
I was able to buy one at a Specialized shop.
The bolts for the rack need to be short. I think the ones I used were 10mm.
I used a old spare Blackburn Crossrack. I like these racks because they don't weigh much and the thin plate acts as a rear fender to keep your back clean if the road is wet.
Hi,
after buying a second Spec for my partner (owns an EQ Vado fullpower) I bought also one for myself. so we do have 2 Vado-sl's 1.1 now as secodnairy lightweigth bikes.
I've added a pair of Hebie Alumee fenders with rack to these bikes (52mm variant which needs some modification to fit the fork) and those work nice. Being Dutch we also need a cafe/ring lock on these bikes and a secondary lock to fix these bikes to a hard-point. Axa flexi mount with an Axa Defender.
Also i've put a Sigma ROX4.0 on the bikes which fit the original TDC mount, works fine with the DU and has navigation in it. At the current pricing super deal.
btw weird sizing with those bikes, my partner had a Como first gen (DU bracket failure... as many) which was a Medium, the full power Vado is a Large with the same geo and these Vado SL in size Xtra-Large have a 1 cm shorter reach comaprerd to the Large Vado. al in all great bikes.
