BUZZ BARS – ISIS 160mm V2 – Lekkie
Currently the only options for crank arms for the Hydra are the aluminum and carbon versions from WW. I came across two possible alternatives from Hope Tech and Lekkie. The Bafang Ultra uses the ISIS mount so I’m pretty sure these would fit but the question is the offset and frame clearance. The Lekkie arms are probably the better bet as far as fitment as you can get them in a wider offset which should clear the frame on the Hydra. I’ll have to send them an email to confirm as well as Hope. If these two will fit the Hydra it will give us alternative options and lengths vs what comes on the bike. Keeping fingers crossed.
