Badoem
- Europe
Hey
I currently have a 350w 10.4ah bike
I would currently put a parallel connection on it with 2 cheap online batteries Wich I after wrap with (electrical) tape in a saddle bag or search a shock proofish box for it . They must have the same "status", voltage and % charge when connecting at the start, from then on it doesn't seem to matter cause unless the connection is broken what happens to one happens to the other from what I read (maybe some isolation). Each will have a xt60 male connector that I then solder on. Then a switch with females to keep the current battery compatible.
Another controller that can control output and later the motor.
Now that the question is about the cabling and battery compatibility, and rightness of my values and and the possibilitypossiblity suppose I already change the cabling from the motor to 5,26mm² would this extremely limit of my current 10.4 ah over foldable bike distances? And damper the current performance.
I chose 5,26 I think 10 awh cause 750-1000 what's seems what the battery is for
the programmable controller can potential also limit the output of my wrongly bought 30ah 48v maybe?
I I'll get a discharge/charge device which might also act ass a measures USB..
Can I charge the battery via de 2 parrellel charges batteries at the same time?
This also seems removable I'll eventually change the frame and brake for suspension on the back.
