StanMiller:
Thanks for the post and tips.  I have the 21D version of this same bike.  I love the way it "fits me".  Old injuries and an aging body and well...  I guess I just needed a comfort bike.  I really appreciated finding that it could indeed be done.  I thought about just buying one of the eGo versions of the Electra Townie from the local bike store.  It was $1499 about 2 weeks ago.  Went back in 3 days ago and sold out.  Apparently they are popular all the way around dang it...
Given how few miles are on my bike it also seemed a shame to buy a replacement for it already.  I find the hills we have around here a bit... punishing given the shape I am in at the moment.  After test riding some RadPower bikes it became clear to me that I like my Townie better and I want an e-bike desperately.
I went looking at the links you put in your post, and being a total newbie at all of this, and they looked great to me.  But I think I would ask as I was narrowing down my selections if there were any updated thoughts or suggestions you might have after so many miles?  I would love any suggestions etc...
I suppose one question I would love an answer too if you have any thoughts.  If it were you would you convert the existing bike?  Or would you go and buy the new factory one?  The new one is only 7d, but with a motor it might not matter so much, and has disk brakes already, but no throttle PAS only and I admit I really did like that feature on the RadPower I test rode.
Joshua
Hey there!
I still love my custom Electra Townie. It’s relatively light, fast, and fun to kick around.
When I started this project in late 2018, I wasn’t ready to drop $1500 or more on an entry-level bike like those from Juiced or Rad Power. And I liked my bike. Installing a kit was the least expensive option and I was pleasantly surprised by the ease of integration with the Bafang kit from Bluenergy.
Nowadays there’s a lot more starter bikes to choose from in the sub $2000 range. The Rad Power bikes are more refined. And there is a big user following plus third party upgrade support. Pretty cool.
As
@EMGX suggests, you should be comfortable tinkering with your bike to do a conversion. Or wanting to learn. You may need to remove/reinstall this or that (i.e. to install the display, throttle, PAS sensor), cassette, adjust the derailleur, brake alignment, and so on…
These Bafang SWX02 motors are really good on flats and moderate hills, but they are by no means long hill climbers. The bike plus me tips the scale at about 250 lbs. When I’m climbing something steepish, I drop the PAS down to 1 or 2 to lessen the burden on the motor. And it does fine.
These Bluenergy bike controllers are on the fast side at the lowest assist, PAS 1. On a full battery, it will accelerate to 10 mph before leveling off. That can be annoying if you’re on a busy greenway trying to navigate around pedestrians, dogs, and other cyclists. In these cases, I drop to PAS 0 and pedal normally and maybe bump the thumb throttle here or there. I’ve thought about looking into if it would be possible to swap out the Bluenergy controller with a programmable KT version.
A definite advantage of going the Bafang SWX02 route is availability of parts, choices of batteries, and so on… If something breaks, you can swap it out. After 5000 miles, I’ve only had to replace the clutch/gear assembly on the motor. These motors have nylon gears and eventually they wear down and the motor gets noisy. But that was an easy swap.
I have the same Bluenergy kit on my Mongoose Envoy.
https://electricbikereview.com/forums/threads/mongoose-envoy.33132/
Given the choice today, I’d still integrate with a kit.  Good luck!
