marvelman
Hi everyone. I’ve put about 900km on my Orbea Gain D50 (Ebikemotion X35 rear hub motor) since purchase last autumn, but it’s recently started to make a clanking/grating noise when freewheeling.
The noise is definitely coming from the rear hub - I’ve removed to wheel and confirmed.
I’m guessing it could be a bearings/dirt issue, but I have zero idea how to get to the hub!
How on earth do you get the magnetic lock ring tool off? I’ve got a standard Shimano cassette lock ring tool with a guide pin, so that doesn’t work (the pin just immediately contacts the protruding threaded axle before reaching the lock ring - there’s no inner ‘void’ as with a QR skewer setup) and while my Shimano freewheel tool can clear the axle, and seems to fit in the splines, it’s not a very satisfactory fit and I can’t budge the thing at all. (I.e. with serious pressure + chain whip). Plus, I thought it was a free hub on the Gain rather than a freewheel anyway, so probably wouldn’t work either way!
My other question: is the hub even serviceable with the Ebikemotion X35 motor, or is this a take-to-dealer job?
Cheers.
PS. Weirdly, while researching this issue online, I came across a YouTube video someone has posted that shows the exact same symptoms I’m experiencing:
(I left a comment asked the poster how he fixed it, but no response yet!)
Cheers.
