stanmiller
For those looking to do a custom build, the Mongoose Envoy is an excellent choice. In November 2019, I converted my Envoy to an eBike with a 500W Bafang hub kit from Bluenergy. I’m now at 1200 miles.
You’ll find other Envoys converted with mid-drives, but I chose a hub to maintain the tractor-trailer-like gearing. Even without battery power, the bike remains very pedal friendly on the smallest chainring with a 22x34 ratio yielding 17.36 gear-inches of go. The bike will walk up a hill.
Today, the Envoy is only available through Amazon. The price fluctuates between the $700’s down to the upper 500’s. So if you monitor the listing you can catch a deal. I would budget $1500 for the bike plus conversion. Then you can upgrade other bits from there.
The first tweak was the kickstand, swapping the wobbly OEM stand for a Ergotec Double Flex 3. Parked, it’s now on solid footing.
I recently upgraded the drivetrain to a 9-speed Microshift Advent shifter/derailleur combo increasing to a 27 speed. With Advent, I can go up to a 42t rear cog giving even more climbing ability.
The list of upgrades with links follows.
Links
Ergotec Double Flex 3 Kickstand
www.ergotec.de
Bluenergy: BAFANG Rear Wheel 500W 48V Hub Motor with SW102 Display
TRP HY/RD Road Hydraulic Disc Brake Caliper Black with Rotor
MicroShift ADVENT Right Trigger Shifter 9 Speed w/bearing
MicroShift ADVENT Rear Derailleur - 9 Speed w/ Clutch
Satori Animaris Bike Bicycle Suspension Shock Seatpost - Mountain Bike or Road Bike 27.2x350mm
Sun Ringle Rhyno Lite XL Rim 26"
Amazon.com: Mongoose Envoy Cargo Bike with 26-Inch Wheels in Grey, Medium/Large Frame, with 8-Speeds, Shimano Drivetrain, Aluminum Cargo Frame, Internal Cable Routing, Mechanical Disc Brakes, and Center Kickstand: Sports & Outdoors
www.amazon.com
Links
Kickstand "DOUBLE FLEX 3" - Ergotec
Amazon.com : TRP HY/RD Road Hydraulic Disc Brake Caliper Black Rotor Front 180mm : Sports & Outdoors
www.amazon.com
MicroShift ADVENT Right Trigger Shifter 9 Speed w/bearing | Tree Fort Bikes
www.treefortbikes.com
MicroShift ADVENT Rear Derailleur - 9 Speed w/ Clutch | Tree Fort Bikes
Amazon.com : Satori Animaris Bike Bicycle Suspension Shock Seatpost - Mountain Bike or Road Bike 27.2x350mm : Sports & Outdoors
www.amazon.com
Sun Ringle Rhyno Lite XL Rim 26" | Tree Fort Bikes
